ProMeth PM190 pump review. - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 08-14-2019, 04:24 AM   #1 (permalink)
No longer in KY
kywhitelightning's Avatar
Drives: 98 VR-4
kywhitelightning Level 1kywhitelightning Level 1kywhitelightning Level 1
Feedback Score: 16 reviews
Default ProMeth PM190 pump review.
Initial testing with this pump showed I had a healthy voltage drop in my electrical system which made this pump perform slightly worse than its smaller Devil's Own counterpart. The pump is physically larger than the standard size pump and draws a few more amps. If you run a progressive controller from another alky vendor you may want to contact them about this pumps amp draw before you purchase it. The Devil's Own draws 10amps and the ProMeth PM190 draws 16.5amps. I also have a Snow Performance pump that draws 11amps. The ProMeth pump will draw 150% of what the other pumps on the market are going to draw. That's why initial testing showed the ProMeth pump was under performing vs the Devil's Own pump.
10.78 at 132 at 3900lbs on teeny tiny turbos.
kywhitelightning is online now   Reply With Quote Quick reply to this message
Old 08-14-2019, 04:42 AM   #2 (permalink)
No longer in KY
Drives: 98 VR-4
Default
My meth system at one time was measured to flow around 3000ml/min with a Devil's Own pump, a Snow pump, and 3 Devil's Own DO14 nozzles. Simply repairing the voltage drop and running the PM190 in place of the old Devil's own pump netted a rather large gain in system performance. Measured total flow now with 2 pumps, one PM190 and a Snow pump, and 3 DO14's is now up to 3875ml/min. That's pushing all 3 nozzles to near their max advertised flow of 1340ml/min. I am impressed with this pump's performance and am glad I purchased it.
It isn't for a small single nozzle system. This pump I would only recommend using for large nozzle systems and multiple nozzle systems where large volumes of flow is needed. The picture attached is total system flow for 1 minute.
Old 08-14-2019, 08:38 AM   #3 (permalink)
Elevate
vSol's Avatar
Drives: '95 3000gt VR-4
vSol Level 1vSol Level 1
Feedback Score: 4 reviews
Default Re: ProMeth PM190 pump review.
wow that's a lot
1995 VR-4, 1992 Stealth ES
vSol is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 11:29 AM   #4 (permalink)
I've been here way too long
donniekak's Avatar
Drives: 91 tsi
donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2
Feedback Score: 14 reviews
Electric motors are current hogs. They’ll show you the weak link in your power supply setup quick.
Running high boost and high base pressure with Walbro 450’s had me melting 30a relays.
donniekak is offline   Reply With Quote Quick reply to this message
Old 08-15-2019, 06:13 PM   #5 (permalink)
Forum user
Unlogic's Avatar
Drives: 3000GT TT 1996
Unlogic is an unknown quantity at this point
Feedback Score: 3 reviews
That's one beefy pump!
Unlogic is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
