how to disengage anti theft - Page 4 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 01-04-2010, 12:35 AM   #31 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
vr4_rider is an unknown quantity at this point
Feedback Score: 61 reviews
Default Re: how to disengage anti theft
Ahh, gotcha..that's right..hot wire and hard wire..
I found this:
Stealth 316 - Fuel Pump Hot Wire
If I am not getting power now, that should give my fp the power it needs right?
Once this problem is fixed, watch out for another thread from the dead..lol.
vr4_rider is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 08:53 AM   #32 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 1Kibwe Walker Level 1Kibwe Walker Level 1
Feedback Score: 6 reviews
I found this:
hardwire the FP
and see if it is working.
If it works by hardwiring it the stock wiring and relay is the reason it won't work under normal conditions because the pump itself is fine, it just isn't getting power.
So once that is identified as the problem you can go about testing relays and hotwiring your car.
Red 93 RT/tt project car
Mods: stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, dsm SMIC's, Tein S springs, pte 580 inj's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
94 vr4: RIP 4/16/09
Kibwe Walker is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 01:10 PM   #33 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
I already did hardwire it. I took connected pos of battery to powerof fp. I took negative of battery to ground of fp. That's what you mean right? If so, my fp is functional.
Old 01-04-2010, 03:51 PM   #34 (permalink)
Drives: 93 RT/tt
yep thats a hardwire
so somewhere in the stock setup is the problem and reason you are not getting fuel.
All that aside if you were cranking it for that long you should be able to see oil at the valves.
Old 10-03-2019, 05:25 PM   #35 (permalink)
Registered User
jjcruz is an unknown quantity at this point
Feedback Score: 0 reviews
here is the solution :
https://www.3swiki.org/Alarm:_Disable_Factory_Alarm
jjcruz is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
