Water pump questions. - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-07-2019, 02:12 PM   #1 (permalink)
Forum user
HOTROB's Avatar
Drives: 93'+98' 3Kgt SL DOHC
HOTROB is an unknown quantity at this point
Feedback Score: 1 reviews
Default Water pump questions.
So again, I am making a new post because all work has come to a stop waiting to find an answer. I hate to start posts for each question, but it's the only way I can get a response. And of course I am sitting around with tools out and everything uncovered with possible rain headed this way.
So my questions are....
First, the replacement pump came with soft gaskets, and the one on it had a metal gasket between the water pump assembly. The gasket that mates to the block is soft like the one on it was, but there was tons of what looked to be black RTV on both seals and gobs of it coming out around everything.
So is it OK to use the soft gasket? And the manual says nothing about using anything with the gaskets. Should I use the rub on permanent for seals, or should I use black RTV.
https://youtu.be/ub3usZoCP-c
HOTROB is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 02:19 PM   #2 (permalink)
Doc
68Whiskey's Avatar
Drives: 93 VR4, 91 GTO
68Whiskey is an unknown quantity at this point
Feedback Score: 6 reviews
Default Re: Water pump questions.
I like doing a job only once and particularly despise water pump leaks, so I use a gasket along with a thin layer of black RTV on both sides to ensure a proper seal.
Mechanic preference I guess.
BSN, RN, EMT
68Whiskey is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 02:33 PM   #3 (permalink)
SDSU Alumnus
bboyalan's Avatar
Drives: VR-4, EVO VIII & X
bboyalan Level 1bboyalan Level 1bboyalan Level 1
Feedback Score: 44 reviews
+1 with the above mentioned - definitely a preference. Regardless, make sure that the surface is clean.
Permatex actually offers an RTV that is "water-glycol" resistant much like their commonly used one for parts that see oil.
https://www.permatex.com/products/ga...licone-gasket/
For certain metal gaskets, I will sometimes use their copper spray. Just my two cents.
Good luck!
3/S Street Tuner San Diego's Panda VR-4 - fully gutted w/ lots of deletes! 3094 lbs as of 7/2/19
'10 EVO X SE - AEM WMI, COBB SF, K&N UICP, Tomei Titanium CBE - 300//350 on 91+Meth
'04 EVO VIII SSL - CBRD BBK Full turbo, full support, lots of suspension - 350 on Pump-E85
'92 VR-4 - Panda v.3 build - Fully built, AEM EMS S2, MHI EVO3 16G's, and Pump-E85 (for now)
"There are no secrets better kept than the secrets that everybody guesses."
bboyalan is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 02:33 PM   #4 (permalink)
Forum user
HOTROB's Avatar
Default
BSN, RN, EMT
should I go out and grab some avtual black RTV or would one of these that I have work?
Old 06-07-2019, 02:34 PM   #5 (permalink)
Doc
68Whiskey's Avatar
Good luck!
I agree, I use the copper spray on many gaskets with phenomenal results.
The water pump & thermostat housing RTV bboyalan mentions does work great- it fixed a water pump o-ring leak for me a while ago, when nothing else worked.
BSN, RN, EMT
Old 06-07-2019, 02:36 PM   #6 (permalink)
Doc
68Whiskey's Avatar
That Permatex Ultra Grey or Black should be fine. Dont use copious amounts - just a nice thin bead.
BSN, RN, EMT
Old 06-07-2019, 02:41 PM   #7 (permalink)
Forum user
HOTROB's Avatar
Default
BSN, RN, EMT[/QUOTE]thanks I wasn't sure if the black would be ok since it isn't labeled an RTV. I am leaning on ultra grey because of the heat tollerance. The black silicone has no heat rating listed on it.
Old 06-07-2019, 04:56 PM   #8 (permalink)
Doc
68Whiskey's Avatar
I've used both just depending what I've had on hand they'll work.
BSN, RN, EMT
Old 06-07-2019, 05:13 PM   #9 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3
Feedback Score: 50 reviews
The OE metal gasket is best, but if the gasket surfaces are pitted, you risk it leaking. I would not use the paper gasket myself, but if I did, I'd use a gasket dressing like high tack or equivalent. I would strongly advise against using any RTV on a paper gasket. It will eventually just turn into a mess.
If the surfaces are not in a condition to accept the metal gasket, I would use no gasket at all, and seal it with anaerobic sealer or a good quality RTV.
RealMcCoy is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 05:39 PM   #10 (permalink)
Forum user
HOTROB's Avatar
Default
I am guessing this is not a good sign.
https://youtu.be/zA7EdphEjuc
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
