Transfercase oil change - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-06-2019, 12:16 AM   #1 (permalink)
Forum user
Stez is an unknown quantity at this point
Feedback Score: 0 reviews
Default Transfercase oil change
So I finally got my redline oil in stock and decided to change the oil in the transfercase. I opened the dill hole then the drain hole and maybe 30 drop cane out of it. I was like oh ho I guess I should of checked it before I bought the car, had lots of metal on the plug. So I filled it with shock proof and am hoping for the best. But I have to admit I’m a little worried about there being no oil in the transfercase.
Stez is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 05:00 AM   #2 (permalink)
Marshall Taylor
Marshall Taylor's Avatar
Drives: 95 VR-4/67 Pro Vette
Marshall Taylor Level 1Marshall Taylor Level 1
Feedback Score: 35 reviews
Default Re: Transfercase oil change
Originally Posted by Stez View Post
So I finally got my redline oil in stock and decided to change the oil in the transfercase. I opened the dill hole then the drain hole and maybe 30 drop cane out of it. I was like oh ho I guess I should of checked it before I bought the car, had lots of metal on the plug. So I filled it with shock proof and am hoping for the best. But I have to admit Im a little worried about there being no oil in the transfercase.
With metal shavings you already have chewed up parts. With only 30 drops of lube it must have a leak. Your TC will fail at some point. Should you desire to send it off to be rebuilt, consider Chris. He is a vendor on this site and does outstanding work.
Chris @ Rvenge Performance
Good luck,
Marshall
Stage 3 80 over Pampena Strocker, Crower Rods, DR Race Cams, UO Cam Gears, A-1 Head Studs, Stage 3 Heads / 1mm oversize valves / flows 300+ CFM / Pampena Headlift fix / Hi Rev Springs / Titanium retainers / 3rd Gen Lifters, Italo's Oil Pump Gears, Twin PTE Billet Dbl BB Turbos rated 610 HP each, Custom T3/T4 Long Tube Manifold Kit, Tial WGs, Tial BOV, Custom Upper Plenium with Q-45 90 mm TB, ID 2000 Injectors, 1100 HP FMIC, Big Weldon External Fuel Pump with street controller, Tank Sump, -12 AN Russell Pro Flex Supply / -8 AN Return, 25 Row Oil Cooler, 6 Qtr. Racing Oil Pan, Bellhousing Brace, RPS Twin CC Clutch, DR 6 Sp End Housing, 300m Output Shaft, M/W Input Spool, 6 Sp TC Brace, CFDS, Rays 300m Rear Axles, Stage 3 Snow Boost Cooler, 75HP NOS Wet Shot, Okada Plasma Ignition Booster, Stewart Electric Water Pump, Custom Expansion Tank, PWR Raditor, True 3" Dual Exhaust with Electric Cut Outs & X-Pipe, Mechman 220 Amp Alt, Solid Mounts, Pampena built Trans & TC. AEM Gauges, AEM V-2 Stand-a-lone, Twin Spal Fans, HKS Coil Overs, Wilwood Big Brake Kit, Stainless Steel Brake lines, Solid rear diff & shifter bushings, Custom PVC Set Up, Volk Upper Curved Rear Control Arms.
Marshall Taylor is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 06:29 AM   #3 (permalink)
TPW: The Prophet
AlmosN8kd's Avatar
Drives: without wearing much
AlmosN8kd Level 1AlmosN8kd Level 1
Feedback Score: 46 reviews
Was the car level (up on 4 jack stands or a lift)?
There is only about .3L that goes into the transfer case (so, not a lot); and, if the car is picked up from the front only, a good portion of it could be in the tail shaft section.
If the car was level, then I would definitely be concerned; however, if the car was up at an angle then you may be a little over concerned.
Slightly Modded! --> 1994 Dodge Stealth R/T Twin Turbo <-- Slightly Modded!
1994 Dodge Stealth R/T Twin Turbo (Slow)
My slow car-->13.097sec at 107.73mph<--My slow car
2016 Honda Pilot Touring AWD (Don't ask)
2012 Honda Civic Si Sedan (It gets me to work and back)
2009 Honda CBR1000RR ABS (Fast enough)
AlmosN8kd is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 07:17 AM   #4 (permalink)
Forum user
Default
It was only lifted in the front but since there wasn’t much oil I did pull the jack stands and lowered it so it was level and nothing came out after that so ya I am concerned, however I’m not hearing any malice and it drives perfect still and I do plan on getting the transmission and transfercase rebuilt in the near future so hopefully it will hold up until I get all the money for it.
Old 06-06-2019, 10:38 AM   #5 (permalink)
TPW: The Prophet
AlmosN8kd's Avatar
Until the rebuild, just keep an eye for puddles under the car and for oil soaking around the transfer case anytime you're under the car. If it has a leak, it doesn't take much for it to all leak out since there is so little in there to begin with. And, overfilling isn't much of an option since it will all bubble out the breather hole at the top when the oil heats up and expands (which could cause you some confusion thinking you have a leak when you don't). If I was you, I'd get it rebuilt as soon as possible to make sure it is good and give yourself the piece of mind that you can trust it. If it fails and/or runs out of oil, it will lock up while driving, causing the rear wheels to lock up and potentially wreck the car as well as destroy the VCU in the transmission. If you do some research on the transfer case recall from several years ago, there are some horror stories of this happening to folks while driving; and, unfortunately, these are no longer covered by Mitsubishi so you'd be out any and all damages associated with a transfer case failure.
But, doom and gloom aside, be sure to keep the oil full and you can go for a good long while, you'd just have to figure out how frequently to check it is all.
Old 06-07-2019, 05:09 AM   #6 (permalink)
Marshall Taylor
With metal shavings on your TC drain plug damage has already occurred. It's good you are going to have it rebuilt ASAP.
Marshall
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
