Need to know the fuel pressure. - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 08-08-2019, 10:39 AM   #1 (permalink)
Forum user
HOTROB's Avatar
Drives: 93'+98' 3Kgt SL DOHC
HOTROB is an unknown quantity at this point
Feedback Score: 1 reviews
Default Need to know the fuel pressure.
So I just dropped off my old high pressure fuel. Line to have a new one fabbed. The guy who is doing it told me he needs to know the maximum fuel pressure.
Can anyone tell me what it is?
HOTROB is offline   Reply With Quote Quick reply to this message
Old 08-08-2019, 01:11 PM   #2 (permalink)
Forum user
white93gt's Avatar
Drives: '93 na atx 3kgt DOHC
white93gt Level 1white93gt Level 1
Default Re: Need to know the fuel pressure.
Our cars run in 35-50 psi range, so a 100 psi maximum rated line will allow for plenty safety margin.
white93gt is offline   Reply With Quote Quick reply to this message
Old 08-10-2019, 12:06 PM   #3 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3
Feedback Score: 50 reviews
A turbo car running high boost can get north of 80lbs... I run 52psi base pressure and at 22lbs boost, that's 74 psi.
Most high pressure fuel hose has a max working pressure rating above 200psi.
RealMcCoy is offline   Reply With Quote Quick reply to this message
Old 08-12-2019, 12:39 PM   #4 (permalink)
Forum user
jrhorne's Avatar
Drives: 91 3000GT VR4
jrhorne is an unknown quantity at this point
Piggybacking on this thread a little because i had a question about the fuel return hose. Stock fuel system on a 91 VR4.
Does the fuel return hose that comes off the FPR just slide on both ends? So it can easily be replaced without needing any fittings, etc? I can see the FPR side but not really the other side with the battery still in place - i just want to make sure i can easily replace this section of those with one off the shelf of the appropriate length.
I was trying to pull off the fuel return hose yesterday because i was lifting the fuel rail to remove the injectors and the hose ripped at the nipple on the FPR side. There might be enough extra length for me to just reuse the existing hose but i might replace while i have other stuff off.
Gt-347 Turbo Kit (~13g)--RC 550cc Injectors--Denso Fuel Pump--Apexi S-AFC II--Turboxs Boost Controller--3sx Air Filter--DNP Stainless Intake Pipe Kit--Turboxs BOV--Autometer Boost Gauge--AEM UEGO Wideband O2--EK2 Downpipe--Gutted Precats--Testpipe--Polished VR-4 Plug Wire Cover, Valve Cover, & Plenum--Stage 2 Twin Turbo Clutch Kit--Full Bomex Body Kit
jrhorne is offline   Reply With Quote Quick reply to this message
Old 08-12-2019, 01:13 PM   #5 (permalink)
RealMcCoy's Avatar
Yes, it's just standard fuel injection hose, clamped at each end. It's in the vinyl sleeve that gets really hard with age, you may need to replace that too, but sometimes you can warm it up with a heat gun and be able to work with it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
