Miss fire and lean idle continues. - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-27-2019, 11:51 PM   #1 (permalink)
The dark shall be with us
Devilmightcry's Avatar
Drives: 93' VR4
Devilmightcry Level 1Devilmightcry Level 1
Feedback Score: 19 reviews
Default Miss fire and lean idle continues.
I decided to make a new topic since this problem I have is now with MAF-T. I tried to change the settings from injector size to maf size and nothing changes. For some reason my front bank doesn't run same as the rear bank till I get some load on the engine. Even when I'm driving on slow speed like neighborhood or parking lot. It misses very bad. I have no idea what the problem is. I even switch the injectors to 900cc this time since I was maxing out the 800cc but it seems it runs even worse with these injectors. Is it because the injectors are too large for ECU to control? This is embarrassing when I drive through car meets. For some reason even when driving 30-40 and I give it 6-8% throttle it goes to very lean again and you can even hear it on the exhaust tone how lean it's running. Car is running great if I give it more than 9% throttle and running full throttle. I looked around and some other DSM people have has lean idle issue too but I never got to see what their solution was (if they ever figured it out at all). Mid and high fuel trims are 100% but I can't get the low trim above 72%. I once got it to 86 but went back to 72 after driving it around for a short time. Any one else has had this problem? is this the best I can get for these injectors and stock ECU and MAF-T? I can't be the only one with large injectors and the maft. Oh and I have the basic MAF-T and not the pro version. Video doesn't show clearly when the car is missing but when I'm driving and it goes lean. That's when it misses. I even show Data logger and as you can see front bank runs lean till I get to 2k RPM.
https://youtu.be/AlZ1An3cLW0
Devilmightcry is offline   Reply With Quote Quick reply to this message
Old 06-28-2019, 12:01 PM   #2 (permalink)
My car is a money pit
futurevr4man's Avatar
Drives: 93 VR4, Boosted FRS
futurevr4man Level 1futurevr4man Level 1futurevr4man Level 1
Feedback Score: 14 reviews
Default Re: Miss fire and lean idle continues.
All you have for tuning is the MAF-T, or do you have Chrome as well? What settings are you using on your MAF size? (there are 4)
futurevr4man is offline   Reply With Quote Quick reply to this message
Old 06-28-2019, 02:43 PM   #3 (permalink)
I've been here way too long
donniekak's Avatar
Drives: 91 tsi
donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2
Have you tried turning the idle and low load knobs a couple clicks richer?
Both banks never run the same, that’s one of the reasons to degree cams.
donniekak is offline   Reply With Quote Quick reply to this message
Old 06-28-2019, 03:54 PM   #4 (permalink)
Drives: 93' VR4
I just have safc and MAF-T. I tried everything. It's maxed out rich for the idle for the MAF-T and mid knob. when I make it rich with safc only the rear gets rich and it gets even rougher. Front stays lean according to the factory o2 sensors no matter how rich I make it with safc. Could it be that I gutted the maf sensor? And it's not reading air flow correctly? I didn't want any restriction so I removed the screen.
Old 06-28-2019, 07:48 PM   #5 (permalink)
One fix at a time
TurboSinceBirth's Avatar
Drives: 95 RT/TT
TurboSinceBirth Level 2TurboSinceBirth Level 2TurboSinceBirth Level 2TurboSinceBirth Level 2TurboSinceBirth Level 2
Feedback Score: 40 reviews
I had my front bank show really lean but it ended up that my 02 sensor was not cycling. If you watch your voltage for your front 02 does it cycle back and forth between 0-1V?
TurboSinceBirth is offline   Reply With Quote Quick reply to this message
Old 06-28-2019, 07:52 PM   #6 (permalink)
Drives: 93' VR4
It does after I give it some gas.
Old 06-28-2019, 11:56 PM   #7 (permalink)
Warzone's Avatar
Drives: 1992 3000GT VR4
Warzone is an unknown quantity at this point
Feedback Score: 3 reviews
does the problem go away when you return to the stock stuff? MAFT's and SAFC's are problem prone up the wazoo.
1994 Panama Green 3000GT VR-4
1992 Ascot Silver 3000GT SL
2004 Velocity Red Mazda RX-8
Warzone is offline   Reply With Quote Quick reply to this message
Old 06-29-2019, 12:25 AM   #8 (permalink)
Drives: 93' VR4
I haven't gone back but I did have missing issue when I was running 800cc injectors and safc with stock maf. I don't know. I bought a new gm maf and see if that help. If not then I think it's the ecu that can't control the injectors.
I sold my older injectors so can't go to smaller injectors unless I buy a set.
Old 07-01-2019, 11:14 AM   #9 (permalink)
And yes, not having the screen isn't helping. That screen helps to create a more laminar airflow to my understanding. If the air gets too wonky and turbulent, the MAF reads funky
Old 07-02-2019, 08:02 PM   #10 (permalink)
Drives: 93' VR4
Unfortunately it's not the screen either. I bought a new GM mas and it is still doing the same thing. I bought a set of brand new 950cc FIC injectors and see if that helps. I never had this problem till I switched the injectors so let's hope that'll resolve my problem.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
