Front Active Aero Bypass? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-03-2019, 11:25 PM   #1 (permalink)
Fear the Reaper!
tensecs2fame's Avatar
Drives: 95SPVR4-91VR4-M35X
tensecs2fame is an unknown quantity at this point
Feedback Score: 34 reviews
Default Front Active Aero Bypass?
If I understand the wiring schematic correctly, the front active aero uses pin #1 and #2 to send a 12v signal to pin number #4 (guess it's some kind of limit switch). If we ran a 12v directly to pin number #4, I have a suspicion that we'd be able to bypass the front active aero by fooling the AA ecu that it's always in both up and down position in the front. I may try this in the next couple of days (for science ) I doubt the motor itself sends an error back to the ecu if it's disconnected and only cares if it's up or down. Thoughts?
---------------------------------------------------^ Yup it's a Spyder Vr-4
tensecs2fame is offline   Reply With Quote Quick reply to this message
Old 06-05-2019, 01:54 AM   #2 (permalink)
1g lip guru.
DarkMatterM4's Avatar
Drives: tons of VR4s
DarkMatterM4 Level 1DarkMatterM4 Level 1
Feedback Score: 6 reviews
Default Re: Front Active Aero Bypass?
Wouldn't it just be easier to have the motor there? I've been running both my VR-4s this way for years. Just a motor without any bracketry for the venturi skirt/air dam.
.the ecstasy lasts as long as the gasoline E85.
DarkMatterM4 is offline   Reply With Quote Quick reply to this message
Old 06-05-2019, 11:03 AM   #3 (permalink)
berkleyav's Avatar
Drives: 92 black vr4
berkleyav is an unknown quantity at this point
Feedback Score: 3 reviews
Default
There's s write up on here on how to do that. Think it was called "a.a. manual operation " but i did it in order to control the rear wing. Just 2 relays wired up on the aa computer. If that's what you're trying to do
berkleyav is offline   Reply With Quote Quick reply to this message
Old 06-05-2019, 04:32 PM   #4 (permalink)
Drives: 3000GTs
Albert0 is an unknown quantity at this point
Feedback Score: 5 reviews
Had the same question about this, I'm tired of seeing the front aero assembly without the plastic just to enable the rear control, to me looks the same, pins 1, 2 just activate the internal AA computer relay, but how it knows if it's already up or down?
From the diagram, pin 1-2 just send some voltage to activate that relay (depending of the kinda circular limit switch) and that's it, pin 4 doesn't go to any other thing other than the coil, any link to the double relay bypass?
I've found just the SPTD relay how to.
Albert0 is offline   Reply With Quote Quick reply to this message
Old 06-05-2019, 04:33 PM   #5 (permalink)
Drives: 3000GTs
https://www.3si.org/forum/f1/diy-act...bypass-471376/
Old 06-12-2019, 03:59 PM   #6 (permalink)
Fear the Reaper!
My method works.
Old 06-12-2019, 04:32 PM   #7 (permalink)
Fear the Reaper!
https://youtu.be/za-iKrX8gCw
Old 06-13-2019, 08:05 PM   #8 (permalink)
berkleyav's Avatar
Default
Sorry im not computer savy enough to link the double relay method but maybe someone else can. I just googled "3000gt active aero manual operation" and the website was wordpress.com and it was a link from 3si by stupidvr4 / imclumzy's . that was the directions i used a couple years ago and mine still works to this day
Old 06-15-2019, 12:23 PM   #9 (permalink)
berkleyav's Avatar
Default
How to: Rewire active aero wing for manual operation. Stock switch. https://www.3si.org/forum/f1/how-rewire-active-aero-wing-manual-operation-stock-switch-491785/
Old 06-17-2019, 03:16 PM   #10 (permalink)
Fear the Reaper!
VIDEO -----> https://i.imgur.com/W4QzSGb.mp4) <------- VIDEO
Works for me. I have to get the car on the road to test the speed sensitive activation though. Will probably have the car running next week
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
