Car missing and running lean after injector - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-07-2019, 12:25 AM   #1 (permalink)
The dark shall be with us
Devilmightcry's Avatar
Drives: 93' VR4
Devilmightcry Level 1Devilmightcry Level 1
Feedback Score: 19 reviews
Default Car missing and running lean after injector
Well I never thought to be one of the people asking internet for help but here I am. Lol I changed my injectors to 800cc because I was running out of fuel on e85 and dr650s. I first bought a wrong set and were high impedance fuel injectors since I thought all fat body injectors are low impedance. When I put those on the car was missing and was running lean. I thought there is a vacuum leak somewhere but couldn't find it. Later I found out I got the wrong injectors. So I bought the right 800cc injectors and the car still running lean and missing. Is it possible I'm running safc or could it be something else? I know for sure I didn't drop anything down the intake to bend valves but I'll do compression test tomorrow. I have not driven the car for 5 weeks. I'm super pissed. I thought maybe safc at least would make it run rich but running lean and missing is confusing me. When I was running 650cc injectors I was at -15% on e85 and -20 on gas when idling so I thought I would have plenty of room for 800cc. What are your thoughts? Bad fried ECU? Smaller injectors (would suck since max I could run was 20psi at 113% duty cycle on 650s)? I also noticed my fuel pressure doesn't hold when I shut off the car but I have 40 psi when idling.
Devilmightcry is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 09:48 AM   #2 (permalink)
I've been here way too long
donniekak's Avatar
Drives: 91 tsi
donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2
Feedback Score: 14 reviews
Default Re: Car missing and running lean after injector
What injectors did you buy? Have you tried anything other than idle? Bigger injectors have more dead time and act way smaller than they are with an safc at idle.
donniekak is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 10:16 AM   #3 (permalink)
Drives: 93' VR4
They are denso. It misses even when I give it gas. Could it be the fuel? It's been sitting for a couple weeks. I'll drain and fill it up with a fresh set. https://m.ebay.com/orderDetails?item...d=983816059025
Old 06-07-2019, 10:20 AM   #4 (permalink)
striker3's Avatar
Drives: 93 VR4
striker3 Level 1striker3 Level 1striker3 Level 1
Feedback Score: 4 reviews
5 weeks is not enough time for the fuel to be a problem. I have let cars sit for 6 months without the fuel in the tank becoming a problem.
striker3 is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 10:50 AM   #5 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3
Feedback Score: 50 reviews
Pretty confused by your post...? What were your SAFC settings with the 650's? What are they now? If it's lean, give it more fuel...
Are you sure it's even lean? If you fouled a plug or otherwise caused a misfire, your wideband will only see the O2 in the unburned mixture, and erroneously show lean...
RealMcCoy is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 11:47 AM   #6 (permalink)
Drives: 93' VR4
My wideband shows lean. Like so lean to a point that it won't even show the numbers anymore and says lean. On ethanol I was around -8 with 650s. I even gave it more than that and it gets a little bit richer and then goes lean again. I have e90 in the tank if that would make a difference. Maybe I should put MAF-T and see how that works. Is it possible it's the ecu that is pulling fuel?
Plugs are brand new.
Old 06-07-2019, 11:56 AM   #7 (permalink)
Resident Street Racer
NOMIEZVR-4's Avatar
NOMIEZVR-4 Level 1NOMIEZVR-4 Level 1NOMIEZVR-4 Level 1
Feedback Score: 15 reviews
throw your old injectors back in and start from a clean base. If everything returns to normal, send your 800cc injectors out for clean and flow service.
agreed 5 weeks sitting is nothing.
96 Single Turbo 3000GT VR-4
NOMIEZVR-4 is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 12:10 PM   #8 (permalink)
Drives: 93' VR4
Problem is I sold the older injectors already. Injectors were cleaned and flow matched by the seller.
Old 06-07-2019, 12:17 PM   #9 (permalink)
NOMIEZVR-4's Avatar
which cylinder is misfirig? swap the injector and see if the misfire follows
Old 06-07-2019, 01:38 PM   #10 (permalink)
Drives: 93' VR4
It's pretty hard to see which is missing since I don't see much of drop in rpm when I pull the plugs but it seems like it's the 6th one. Same as when I had the wrong injectors. I'll test and see if I got the right injectors this time and put a MAF-T in while I'm at it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
