Anyone ever had a car built by a shop? - 3000GT/Stealth International Message Center
Ľ Auto Insurance
Ľ Wheel & Tire Center
Old 05-02-2019, 01:43 PM   #1 (permalink)
Amsterdamn
Turbo Beast's Avatar
Drives: 85 Monte Carlo SS
Turbo Beast Level 2Turbo Beast Level 2Turbo Beast Level 2Turbo Beast Level 2
Feedback Score: 9 reviews
Default Anyone ever had a car built by a shop?
Guys,
Iím looking to drop off my car at a shop to get it finished.
I just donít have enough time to get it done.
Any insight on this process? Do they quote you ahead of time when you drop it off?
I need a good cage, another transmission, suspension dailed in and a paint job.
Looking to learn what process I can expect when dealing with a shop.
Wide open in the hammer lane!
Turbo Beast is offline   Reply With Quote Quick reply to this message
Old 05-02-2019, 05:27 PM   #2 (permalink)
Fear the Reaper!
tensecs2fame's Avatar
Drives: 95SPVR4-91VR4-M35X
tensecs2fame is an unknown quantity at this point
Feedback Score: 34 reviews
Default Re: Anyone ever had a car built by a shop?
Honestly, I've gone through all that bs before. The BEST way to go about it is to go to 3 or 4 different shops that ONLY do the one of things you want. Paint go to a paint shop, transmission, go to a transmission place. etc.. You go to a one stop do all, and they'll take forever bouncing around from project to project.
---------------------------------------------------^ Yup it's a Spyder Vr-4
tensecs2fame is offline   Reply With Quote Quick reply to this message
Old 05-02-2019, 05:38 PM   #3 (permalink)
"THE KING"
shadow334485's Avatar
Drives: 94 RT/TT, 11 Raptor
shadow334485 Level 1shadow334485 Level 1
Feedback Score: 17 reviews
Mark (duTTch) can tell you about having everything done at one place.
Sent from my Pixel using Tapatalk
Get your Portable ID!
Originally Posted by AudibleSilence View Post
You can't see it...but I'm making a jerking motion while reading your post.
Respect....lost.
shadow334485 is offline   Reply With Quote Quick reply to this message
Old 05-02-2019, 05:41 PM   #4 (permalink)
vitalivr4's Avatar
Drives: 09 TL, 3000GT VR-4
vitalivr4 is an unknown quantity at this point
Feedback Score: 25 reviews
Originally Posted by Turbo Beast View Post
Guys,
I would recommend the shop abroad, much quicker turn around time, superior quality of works compare to local shops, cheaper hourly rate and the most of them are one stop shop to finish the whole car including paint and upholstery
1992 19T powered VR4,
EAM ems, AEM serial gauge, BLITZ SBC ID3, Front Euro lconversion, RC550, GREDDY FMIC, EIBACH Coil overs, PitRoad M SP wires and Strut bar, HKS Exhaust with custom 4" Tips, HKS DLI, AP Racing BBK, PST one piece CFDS, Upper polished Poly and bottom Solid Motor mounts and too much more
vitalivr4 is offline   Reply With Quote Quick reply to this message
Old 05-03-2019, 06:42 AM   #5 (permalink)
Marshall Taylor
Marshall Taylor's Avatar
Drives: 95 VR-4/67 Pro Vette
Marshall Taylor Level 1Marshall Taylor Level 1
Feedback Score: 35 reviews
Guys,
Is it your Monte Carlo SS you are trying to get finished up? If so, you have more options than a 3s vehicle.
Generally speaking, you can expect to pay $80 per hour for fab and mechanical work. Paint and Body work is usually done by a Paint and Body Shop as suggested. You need to think of a minimum of $6 k if only final prep, prime and paint is needed.
Markoverclock (Mark Shartzer) of OC Customs in Houston, TX can do the cage and mechanical work. Mark is a one man band so don't expect a quick turnaround.
OC Customs
8825 Solon Rd.
Suite H3
Houston, TX 77064
Email: [email protected]
Phone: (281)825-8832
Good luck,
Marshall
Stage 3 80 over Pampena Strocker, Crower Rods, DR Race Cams, UO Cam Gears, A-1 Head Studs, Stage 3 Heads / 1mm oversize valves / flows 300+ CFM / Pampena Headlift fix / Hi Rev Springs / Titanium retainers / 3rd Gen Lifters, Italo's Oil Pump Gears, Twin PTE Billet Dbl BB Turbos rated 610 HP each, Custom T3/T4 Long Tube Manifold Kit, Tial WGs, Tial BOV, Custom Upper Plenium with Q-45 90 mm TB, ID 2000 Injectors, 1100 HP FMIC, Big Weldon External Fuel Pump with street controller, Tank Sump, -12 AN Russell Pro Flex Supply / -8 AN Return, 25 Row Oil Cooler, 6 Qtr. Racing Oil Pan, Bellhousing Brace, RPS Twin CC Clutch, DR 6 Sp End Housing, 300m Output Shaft, M/W Input Spool, 6 Sp TC Brace, CFDS, Rays 300m Rear Axles, Stage 3 Snow Boost Cooler, 75HP NOS Wet Shot, Okada Plasma Ignition Booster, Stewart Electric Water Pump, Custom Expansion Tank, PWR Raditor, True 3" Dual Exhaust with Electric Cut Outs & X-Pipe, Mechman 220 Amp Alt, Solid Mounts, Pampena built Trans & TC. AEM Gauges, AEM V-2 Stand-a-lone, Twin Spal Fans, HKS Coil Overs, Wilwood Big Brake Kit, Stainless Steel Brake lines, Solid rear diff & shifter bushings, Custom PVC Set Up, Volk Upper Curved Rear Control Arms.
Marshall Taylor is offline   Reply With Quote Quick reply to this message
Old 05-03-2019, 09:46 AM   #6 (permalink)
Amsterdamn
Yeah, the Chevy needs finishing up.
Old 05-03-2019, 11:50 AM   #7 (permalink)
1G Foglights b!tches
familyMAN's Avatar
Drives: 1992 VR4
familyMAN Level 2familyMAN Level 2familyMAN Level 2familyMAN Level 2familyMAN Level 2
Feedback Score: 12 reviews
I'd check on yellowbullet for recommendations.
1992 Kilder Green VR4 -
First 4Gswap in a 3S. 9.65 @ 143MPH (37psi) Quickest/Fastest 3S with stock fog lights. Go fast with class!
LSwap 8.84 @ 157.4MPH (26psi+50shot; 5900ft) still keeping it classy
familyMAN is offline   Reply With Quote Quick reply to this message
Old 05-03-2019, 12:00 PM   #8 (permalink)
Amsterdamn
Meh, a thread with an actual question usually gets buried underneath a bunch racist and nws stuff.
Old 05-06-2019, 09:21 PM   #9 (permalink)
Amsterdamn
Went to a local recommendation today, calling Mark next.
Old 05-07-2019, 01:34 PM   #10 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3
Feedback Score: 50 reviews
You'd have a better chance posting in one of the actual racing subforums that are moderated, and staying away from TOBT. I do see some good discussions going on in those pages.
RealMcCoy is online now   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tasca Racing Funny Car shop built Next to 3SX Import Power General 17 01-11-2009 09:46 PM
