Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > DFW3S - NT3S - H3S
Old 09-09-2008, 12:44 PM   #21 (permalink)
Between Shadow and Light
iceman_ii's Avatar
Drives: Abbie & the N/A
iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7
Default Re: Water pump
In 300k, the black car has had neither... and I can say beyond a shadow of a doubt, that while the tube seals don't leak, the front rocker cover leaks like a sieve.
As for the pumpkin, she gets new seals every engine rebuild, which is unfortunately much more often than every 60k
For the minimal cost, it can't hurt.
485 awhp (mustang dyno) on 93 pump gas (~524 dynojet equivalent)
Only 20.5 psi on my lil' ol' GT368s with no water or alky injection
iceman_ii is online now   Reply With Quote
Old 09-09-2008, 04:49 PM   #22 (permalink)
GTwizard Level 5GTwizard Level 5GTwizard Level 5GTwizard Level 5GTwizard Level 5GTwizard Level 5
I have a factory manual and it does not say to do Gaskets and seals at 60k, and at that you are correct. Fezeli's had told me that I should do this as they have had cars come in for the 120K and by then it is to late. oil is all over everything. So I was going by the history they had with these car and the advice of there service manager, and I thought it was way cool that they would even share this info with me. I Am looking out for my customers and may be a little pushy some times. :eek
You are also right in the fact that we are on the same side, that is why we are all on this thread. So, am I selling something you may not need yet. Yes I am. You wouldn't wait untill you tires will no long hold air to replace them. Just as we are replacing timing belts BEFORE they brake.
GTwizard is online now   Reply With Quote
Old 09-09-2008, 05:47 PM   #23 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7
.......... well..... I have been known to drive tires till they pop on my personal vehicles :P
92 Stealth RT/TT Best time: 13.2 @105
StealthCRF is online now   Reply With Quote
Old 09-09-2008, 11:32 PM   #24 (permalink)
Phates's Avatar
Drives: 93 stealth ES
Phates is an unknown quantity at this point
LOL I just want it fixed and done the right way. Granted I dont know hardly anything about these cars *mainly because I've never owned one till about 7 days ago* but still, this is damn near my dream car. (95 VR-4 in case anyone wanted to know) I just want her to run smoothly till i can get out of college and get a job making more than 8.00$ an hour
Phates is offline   Reply With Quote
Old 09-15-2008, 11:04 AM   #25 (permalink)
Bkphate's Avatar
Bkphate Bkphate Bkphate
someone stole a user name -_-
Bkphate is offline   Reply With Quote
Old 09-15-2008, 04:33 PM   #26 (permalink)
Phates's Avatar
haha ask evenflow i've had this one for the last 5years I've used it in MMORPGs on ASEC (avenger seabring club) Z31P ( forum for Z31s) 300ZXclub and a handful of others
Old 09-15-2008, 05:55 PM   #27 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
Trader Rating: (46)
LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7
Did i miss it, but how many miles are on the orginal posters car? Also how many miles since last major service? (60k 120k ect?)
Depending on the above, will depend if the water pump really needs replaced. Our motors use a cross over pipe that spans from the water pump to the water housing, if it sat dry or any rad flush was used they can leak. Is the motor in it factory build? What is the history? It is possible you might not need to go through all the trouble listed above... Has the system ALWAYS and I mean ALWAYS had coolant in it? (Strait water was NEVER run)?
I am just saying a leak doesn't necessarily mean water pump.
1992 Stealth R/T
Drive Train/Performance:
Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
A drivable car!!!!
To Do:
Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned).
LeRoyDL is offline   Reply With Quote
Old 09-17-2008, 10:43 PM   #28 (permalink)
Phate's car has been seen by the GTwizard and has been healed. A full blown 60K with plugs and wires. The water pump was so bad the shaft had enough play to jump time and for the life of me I do not know how he was driving it. When I pulled the timing cover, the belt was engaged by only 2 teeth on the front intake cam gear. It was dollied here after he lost all is water on the way to work friday. He also had spark plug tubes filled with oil. Next month he will be back for axles and ball joints. On that note, Anyone know hoe to get a hold of "customshiftboot" ?
Old 09-18-2008, 08:54 AM   #29 (permalink)
Senior Member
speed3000gt's Avatar
Drives: '94 Stealth RT-TT
Trader Rating: (14)
speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7
search for " ball joints" in the parts for sale section and then look for the thread with the most views.... i think that should work!
EDIT: My method didnt work but helped bring up this Info:
Yea I have them but actually you can get them for 35.00 each shipped paypal is xchvyragtopx@aol.com
Scott
speed3000gt is offline   Reply With Quote
Old 09-18-2008, 10:52 AM   #30 (permalink)
VR3.9's Avatar
Drives: 93 VR4 & 91 VR4
Trader Rating: (8)
VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7
Hey, GTwizard
Custom shift boots.
http://www.3si.org/forum/f4/both-shi...hipped-308384/
FIPK, Megan Racing DP, Gutted Pre Cats, MBC, Walbro Fuel pump, Ground Controls, Unortodox Racing Flywheel, Slotted and Vented Rotors. Maximal Rear adjustable upper control arms. Poly Mounts
Under the Knife for: JDM motor with 25k. 13T's, 550CC injectors, SAFCII. Rebuilt 5 speed 25spline tranny.
VR3.9 is offline   Reply With Quote
