#31 (permalink) |
I'm starting to agree with iceman on this one. I have a set of 15g and a set of 16g (with manifolds ect.) 16g is almost too much hassle, even if you already have everything.
I'm a glutton for punishment and not quite ready to admit defeat. So I'll prob go 16g one more time. After spending all that $$ I'm kinda stuck.
92 VR4 Reborn! - TD05 manifolds with MHI 16g, 6 speed conversion done, Maximal Solid Mounts, front mount 3" intercooler and intake pipes, OFE Stage 3 Clutch (from Southbend Clutch), SS clutch line, SS brake lines, SS oil and coolant lines, borla exhaust, stillen downpipe, egr block-off plates, LC-1 Wideband, blitz dc2 turbo timer, hks ssbov, Maft Pro speed density, Blitz SBC i-D III boost controller w/ Power Meter, k&n filters & custom intake pipes, 18x9 blitz type 03 wheels wrapped in Nexen N3000 tires, intrax springs, adj. control arms, 97 frontend and side conversion, 99 center tail light piece (<--adds at least 20hp on the dyno
#32 (permalink) |
ok, what's the update on this?
![]() FIPK, Megan Racing DP, Gutted Pre Cats, MBC, Walbro Fuel pump, Ground Controls, Unortodox Racing Flywheel, Slotted and Vented Rotors. Maximal Rear adjustable upper control arms. Poly Mounts Under the Knife for: JDM motor with 25k. 13T's, 550CC injectors, SAFCII. Rebuilt 5 speed 25spline tranny. |
#33 (permalink) |
Between Shadow and Light
Turbo pulled Wednesday
Turbo Rebuilt Wednesday Started the reinstall Thursday night
Tonight the plan is to drop in the radiator and reconnect all the IC pipes.
![]() 485 awhp (mustang dyno) on 93 pump gas (~524 dynojet equivalent) Only 20.5 psi on my lil' ol' GT368s with no water or alky injection |
#34 (permalink) | |
luvs spyda gal
#35 (permalink) | |
The Godfather
I SUPPORT FAT CHICKS!
1991 VR4 BPU 2007 Mercedes C-Class (AMG Aero) ![]() |
#36 (permalink) |
TEXAS!! FIGHT!!
I was just messin' with ya, Scott. You damn well know what you're doing with that car and don't need my advice. I just felt the urge to reply with something sarcastic
(TD05's would be more reliable)
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01 (Trevor owns me )E16G's: 11.28 @ 124.7 (Pure pump gas ET record )14B's: 11.10 @ 127.3 (AWD 14B ET record. Take THAT, Trev! 9B's: 12.78 @ 107.1 Congrats to the current top 10 members!! DynamicRacing: US 3S Top 10 Fastest List |
#40 (permalink) |
Well, I just finished it up, I primed her nice and long... I figure for somewhere between 1.5 and 2 minutes. reconnected the CAS, and started her up.
She started, and seemed to have no smoke Its dark so I will wait till the morning for final testing... looking for coolant and oil leaks etc. |
