Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > DFW3S - NT3S - H3S
Old 09-17-2008, 08:22 AM   #1 (permalink)
Between Shadow and Light
iceman_ii's Avatar
Drives: Abbie & the N/A
iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7
Default Turbo is pulled!
Well, its 9:15 in the morning, and I just got the front turbo out, and I am on my way to Majestic in Waco.
Political Correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end...
Author unknown
485 awhp (mustang dyno) on 93 pump gas (~524 dynojet equivalent)
Only 20.5 psi on my lil' ol' GT368s with no water or alky injection
With a wee bit more tuning, I should get it to about 22psi
iceman_ii is offline   Reply With Quote
Old 09-17-2008, 08:25 AM   #2 (permalink)
FSR motorsports
RussianVR-4's Avatar
Drives: 2002 TIsilver M3
Trader Rating: (13)
RussianVR-4 Level 7RussianVR-4 Level 7RussianVR-4 Level 7RussianVR-4 Level 7RussianVR-4 Level 7RussianVR-4 Level 7RussianVR-4 Level 7RussianVR-4 Level 7RussianVR-4 Level 7RussianVR-4 Level 7RussianVR-4 Level 7
Default Re: Turbo is pulled!
GOGO scott!
let me know how it works when theyre done
02 Titanium Silver M3 convertible - stock and FUN!
READ THIS before modifying your car.
RussianVR-4 is offline   Reply With Quote
Old 09-17-2008, 08:32 AM   #3 (permalink)
Winner Takes ALL!!!
Dallas3000GT's Avatar
Drives: '94 3kGT na '91 VR4
Dallas3000GT Level 2Dallas3000GT Level 2Dallas3000GT Level 2
It must be nice to have a job that you can take off in middle the week to work on your car... wish I had a job like that. What was wrong with the turbo in the first place, sorry I haven't been keeping up.
Dallas3000GT is offline   Reply With Quote
Old 09-17-2008, 09:12 AM   #4 (permalink)
hotrodhendrix's Avatar
Drives: 94' VR4/ 91' GT4
hotrodhendrix is an unknown quantity at this point
Majestic does great work. They rebuilt my 13T's and td06 20g which all came out amazing.
"It's not a question of if it will break down but a question of when it does can you afford to fix it."
By: James Hendrix (me)
Pearl White 94' VR4
hotrodhendrix is offline   Reply With Quote
Old 09-17-2008, 11:13 AM   #5 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: NoCar XCase Test Car
Trader Rating: (22)
AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7
Go bigger
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Congrats to the current top 10 members!!
DynamicRacing: US 3S Top 10 Fastest List
AdamVR4 is offline   Reply With Quote
Old 09-17-2008, 11:16 AM   #6 (permalink)
VR3.9's Avatar
Drives: 93 VR4 & 91 VR4
Trader Rating: (8)
VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7
Still can't beleive it would be the front one that went out. I think a lottery ticket is in order.
FIPK, Megan Racing DP, Gutted Pre Cats, MBC, Walbro Fuel pump, Ground Controls, Unortodox Racing Flywheel, Slotted and Vented Rotors. Maximal Rear adjustable upper control arms. Poly Mounts
Under the Knife for: JDM motor with 25k. 13T's, 550CC injectors, SAFCII. Rebuilt 5 speed 25spline tranny.
VR3.9 is offline   Reply With Quote
Old 09-17-2008, 11:22 AM   #7 (permalink)
93 VR-4 DailyDriver
BlinkRA182's Avatar
Drives: Like an A-Hole...
BlinkRA182 Level 2BlinkRA182 Level 2BlinkRA182 Level 2
9am and you have the turbo out already...damn you're motivated!
BlinkRA182 is offline   Reply With Quote
Old 09-17-2008, 12:54 PM   #8 (permalink)
Senior Member
speed3000gt's Avatar
Drives: '94 Stealth RT-TT
Trader Rating: (14)
speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7
Damn that was fast..... the first time i removed the front turbo on one of these cars, it took 2 or 3 hours!!!!!
have a good trip
speed3000gt is offline   Reply With Quote
Old 09-17-2008, 03:05 PM   #9 (permalink)
The new cult king
fearpb's Avatar
Drives: '92 vr-4
fearpb Level 7fearpb Level 7fearpb Level 7fearpb Level 7fearpb Level 7fearpb Level 7fearpb Level 7fearpb Level 7fearpb Level 7fearpb Level 7fearpb Level 7
Well its 4:00 and we got the turbo back from them. I just got done hanging out with scott. I went and picked him up from Majestic and we went and ate at hooters. Then chilled for awhile. Great guy. Fun time.
Stage 3 Clutch, MBC, Matrix Filter, Black Alum. Y-Pipe, Badass driver mod =)
fearpb is offline   Reply With Quote
Old 09-17-2008, 04:49 PM   #10 (permalink)
iceman_ii's Avatar
As Steven said, I got it back from them today... let me say that again...
MAJESTIC TURBOCHARGERS WILL DO SAME DAY TURNAROUND ON WALK IN TURBO REBUILDS.
Granted, the reason they could do a quick turn was that they had all the parts... it ended up needing:
  • A full set of seals and bearings (there was some minor scoring on the main bearings, and a bit too much wear on the thrust bearing)
  • Honed out the bearing in the cartridge (swapped out cartridges, and will hone mine out and keep on the shelf)
  • Replacement shaft due to some scoring, and a replacement hot-side impeller... they even clipped it to match!
I thought about putting it in tonight so I could say I pulled it, had it rebuilt, and put it back together in the same day, but naa... I'm tired, I may start the reinstall, but will probably finish it up tomorrow or Friday night.
FTMFW
