Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > DFW3S - NT3S - H3S
Old 07-03-2009, 04:20 PM   #1 (permalink)
Cabana Boy
vr4operator's Avatar
Drives: People CRAZY!
Trader Rating: (20)
vr4operator Level 1vr4operator Level 1
Default So a guy is going to look at my A/C system...
Lets be honest, I know enough about most engines to get myself out of trouble. Most.
However, A/C is something I never learned/got into. Why would I? One not a fan of A/C, I'm a windows/top down kinda guy. And Massachusetts rarely gets the heat needed for me to use the A/C...
Anyway, awhile back I knew I had a leak somewhere in the system, so I bought one of those 12a to 134 conversion kits in hopes the valves were the issue and call it a day. Yeah, that works for about 2 weeks at a time.
Now I get that red dot on my climate control. I haven't tried putting anything in in over a year tho.
So a friend of a friend fixes A/C. First thing hes gonna do is flush the system, which I never did because I didn't have the equipment necessary. Then hes going to fill it with freon and leak detector and have me drive it acouple days and bring it back.
One question that perplexes me that he asked is, does it have a dryer. I have no idea. I thought if you have A/C you have a evaporator and a dryer. He asks this right after asking what year my car is.
So that my question to you, does a '94 VR4 with a stock A/C system have a dryer?
Thanks,
Butch
"Got Turbo? Meet The Twins"
Car Domain Link
In NY? 3S Motors
In MA? Enhance Street Performance
My '71 Stingray and '94 VR4 .......Proud to continue my 16+ years of honorable service to my country
Pampena Stage 1 block, 15T's, 550cc inj's, Walpro 255, K&N kit, and more...
vr4operator is offline   Reply With Quote
Old 07-03-2009, 06:17 PM   #2 (permalink)
SOCOM Racing League
James92TSi's Avatar
Drives: #388 Red
Trader Rating: (16)
James92TSi Level 1James92TSi Level 1
Default Re: So a guy is going to look at my A/C system...
Yes. Receiver/drier is at the driver front corner of the engine bay. It has the high/low pressure sensor and sight glass on the top of it. It's a silver canister, but the majority of it is recessed into the fender area, so you only see the top of it from the engine bay.
Stealth 316 - AC Compressor Replacement
'91 3000GT VR-4 Jackstand Racing League 2008 series champion.
'03 G35 Sport Coupe Retains transmission and full warranty, even with VDC off!
Originally Posted by Kenneth Ellis
In case you haven't noticed, it's an internal combustion engine; it runs on air, fuel, and a spark being delivered every couple hundredths of a second. It doesn't run on rays of sunshine being blown out your ass with ample amounts of pixie dust and hope.
James92TSi is offline   Reply With Quote
Old 07-03-2009, 06:19 PM   #3 (permalink)
Owns a Jack Stand Queen
VR3.9's Avatar
Drives: 93 VR4 & 91 VR4
Trader Rating: (20)
VR3.9 Level 1VR3.9 Level 1
Ofcourse it does. I've never heard of an ac system with out one. Also called an accumulator. Should be located along the drivers side fender towards the radiator side of the engine bay. You will notice 2 small alluminum solid lines going to it. If you have FMIC it's really in the way of the pipes.
13T's, EVO 560 CC injectors, AFPR, Greddy Profec B, K&N FIPK, SS Headers and O2 housings, 3SX downpipe, CRX racing FMIC, Ground Controls, Maximal adjustable rear control arms, Maximal TC Brace, Poly front and rear mounts, Vacuum Reduction, EGR block off plate, Hot Wired Walbro 255, UR Flywheel, XDC stage 2 racing clutch, Slotted and vented rotors, SAFCII, Turbo XS BOV, 3SX FP hotwire
VR3.9 is online now   Reply With Quote
Old 07-04-2009, 01:11 AM   #4 (permalink)
gearheadvr4's Avatar
Drives: Pucking VR4
Trader Rating: (36)
gearheadvr4 is an unknown quantity at this point
That would kinda worry me about the guy if he's wondering if there is a dryer.
gearheadvr4 is offline   Reply With Quote
Old 07-04-2009, 04:00 AM   #5 (permalink)
Cabana Boy
Trader Rating: (20)
Thanks for the help guys.
As far as trusting him, well, he works on base at the auto shop. Actually, another guy who was going to recharge the system, told me to talk to the guy. Said he'd be cheaper and could flush the system, where they couldn't.
The other reason I can't really go wrong is he doesn't want any money until we know whats wrong. So he'll replace the valves that I know are bad, recharge with freon and leak detector stuff and we'll go from there.
Old 07-04-2009, 04:37 AM   #6 (permalink)
SOHC PowA
rubix_cube's Avatar
Drives: Stealth 94 Black
rubix_cube is an unknown quantity at this point
i have an A/C problem too if anyone wants to help. A/C worked fine before my car was down for a month due to working on transmission, now all A/C does is blow air, not hot, or cold, but heater works, when i turn on A/C i get this loud fast ticking coming from the compressor what do i do?
Performance:Stage "2" TZ Southbend Clutch, Fidanza N/A Flywheel, Custom Push Button Start, Bomz Racing Intake, Konig Unknowns 18's, Federal 245/40ZR/18, Northgate 2'' Custom Catback Exhaust, KYB Shocks & Struts, Intrax Springs, SOHC 5 spd,
Sound: Pioneer HU, Pioneer 6-disc CD Player, Memphis PR 500.1, 2 DD 8's cutom box
140 DB
Interior:
Blue LED's
Blue/Black Shift boot
Custom Gauge
Work in progress:
rubix_cube is offline   Reply With Quote
Old 07-04-2009, 02:08 PM   #7 (permalink)
Cabana Boy
Trader Rating: (20)
Clutch not engaging? You may want to make your own thread about this, as this one has been answered and will get less traffic.
Good luck!
Old 07-04-2009, 07:34 PM   #8 (permalink)
I set ATL on fire.
Gray Haze's Avatar
Drives: 3500GT VR4/87 MCSS
Trader Rating: (26)
Gray Haze Level 2Gray Haze Level 2Gray Haze Level 2Gray Haze Level 2
Might wanna ask someone from North Carolina, or take your car to 3SX for service. None of us are going to drive that far to work on your A/C unless you are planning a trip to Texas, from the sound of your problem, your system is really low on refrigerant, and possibly has a slow leak.
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion.
Ignore the picture. It is no longer an accurate representation of the madness.
www.3stech.org <= Where the meaningful results of your search went.
Gray Haze is offline   Reply With Quote
Old 07-04-2009, 08:32 PM   #9 (permalink)
Combat Tracker
dbest671's Avatar
Drives: 1994 VR-4; 300C SRT8
Trader Rating: (19)
dbest671 Level 1dbest671 Level 1
Wait my 94 says it has the R134A and your did not?
dbest671 is offline   Reply With Quote
Old 07-05-2009, 10:32 AM   #10 (permalink)
Drives: Pucking VR4
Trader Rating: (36)
I'd come up there to work on it for you if you got me a plain ticket...
Feel I'm going back to Massachusetts,
Somethings telling me I must go home.
And the lights all went out in Massachusetts...
You coming back to Corpus anytime soon?
