Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > DFW3S - NT3S - H3S
Old 07-03-2009, 03:03 AM   #1 (permalink)
Dope-stoopid yo!
Mista Grimm's Avatar
Drives: 96 3KGT & 90 ZTT
Trader Rating: (10)
Mista Grimm is an unknown quantity at this point
Default Ok DFW guys please help. Need rear NA head and lower timing cover.
All I need to repair my engine is the rear bank head and lower timing cover, 93-up DOHC only.
----------1996 3000GT -------------------- 1990 300ZX TT Stage III-----
PRETTY MODS:
Philips/Hella HID kit on lows, HID kit on fogs, Active Aero Spoiler,VR4 brake upgrade, Digital AC Conversion, Reverse Indiglo Gauges, Custom black leather seats w/ Red inserts, 18x8.5 Antera 143 chrome wheels, Yokohama ES100 265/35-ZR18 tires, Eibach Springs, K&N drop-in filter, Clarion touch deck, Pair of 12" DVC subs, Short Shift Mod, Flowmaster muffler w/ 4" tips, Hidden white neon tube replacing rear license plate lights, Electric trunk release, Illuminated LED passenger door switches, Fog light mod(independent), Switched low/high beam projector lenses
"Man, if you don't watch where you put that peepee it's gonna end up looking like Megan Fox's thumb."
Mista Grimm is offline   Reply With Quote
Old 07-03-2009, 04:52 PM   #2 (permalink)
VR440 killer!
Drives: 2nd gens w/o hoops
Trader Rating: (85)
DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3
Default Re: Ok DFW guys please help. Need 1 intake cam, CAS, and crank gear.
I have an old cam angle sensor if u r desperate.
there might still be a black dohc 94 in the junkyard near fair park, its a pick and pull. car was in really decent shape engine was still in a month back. Dont remember the name tough. Witts3kgt might rememebr. We just couldnt figure out why the car was there. was it the tranny or was it engine failure. as the body was in tiptop shape for 226k on it.
406 AWHP @ 12psi with methanol on pumpgas
DuTTch is offline   Reply With Quote
Old 07-03-2009, 07:02 PM   #3 (permalink)
hotrodhendrix's Avatar
Drives: 94' VR4/ 91' GT4
Trader Rating: (6)
hotrodhendrix is an unknown quantity at this point
Dude you didnt say you needed a CAS! I even picked it up and showed you lol.
Anyways I went digging and found the gear, tri star, and peg!
So now all you have letf is to find another cam once you come pick these up for the usual price.
"It's not a question of if it will break down but a question of when it does can you afford to fix it."
By: James Hendrix (me)
Pearl White 94' VR4
hotrodhendrix is offline   Reply With Quote
Old 07-03-2009, 08:04 PM   #4 (permalink)
the word ****** is ******
blackrussian's Avatar
Trader Rating: (15)
blackrussian is an unknown quantity at this point
Im not in DFW, but I do have an intake cam. Im about 300 miles away.
blackrussian is offline   Reply With Quote
Old 07-03-2009, 09:02 PM   #5 (permalink)
I set ATL on fire.
Gray Haze's Avatar
Drives: 3500GT VR4/87 MCSS
Trader Rating: (26)
Gray Haze Level 2Gray Haze Level 2Gray Haze Level 2Gray Haze Level 2
Cams are all interchangeable, but make sure if you change to 91/92 intake cams, you do it on both banks.
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion.
Ignore the picture. It is no longer an accurate representation of the madness.
www.3stech.org <= Where the meaningful results of your search went.
Gray Haze is offline   Reply With Quote
Old 07-04-2009, 07:13 AM   #6 (permalink)
Dope-stoopid yo!
Trader Rating: (10)
Well Hotrodhendrix was a Godsend, he gave me the CAS, crank gear, and tri-star part.
Another thing, is there a difference between a front and rear bank intake cam? Well I decided to call out for a rear bank complete head since I might have a concern about valve guides.
Old 07-04-2009, 05:48 PM   #7 (permalink)
I set ATL on fire.
Gray Haze's Avatar
Trader Rating: (26)
The cam profiles themselves are different between 91/92 and 93+
