Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > DFW3S - NT3S - H3S
Old 09-13-2007, 03:36 PM   #1 (permalink)
Htownstealthttman
HTOWNSTEALTHTTMAN's Avatar
Drives: Dodge stealth turbo
HTOWNSTEALTHTTMAN is an unknown quantity at this point
Default Houston, Dodge Stealth Turbo parts
I have a 91 dodge stealth turbo awd 18 spline transmission, with about 204,000 miles on it. It has a crack on the clutch bellhousing, about 5-6 inches long. The vcu is no good, because the oil was tar black when i drained it. When I did a visable inspection of the inside, the gears and other internals looked fine, except the vcu had that black gunk on it. This trans is good for parts or a rebuild, if you have a clutch housing. Doesn't come with the transfercase, because it cracked in half. Asking $125
92 dodge stealth turbo rear red bumper $100
6 speed transfercase, normal wear on spool $175
I also have a 91 dodge stealth turbo with 204,000 miles. Asking $1000. It was running, until i took the transfercase off because it broke. If you buy car, you get transmission listed above. The motor needs rebuild (old gaskets multiple oil leaks) no knocking. This car would be good for parts or a project. When picking up need a trailer, car is not driveable
Everything is pick up only
HTOWNSTEALTHTTMAN is offline   Reply With Quote
Old 09-13-2007, 03:41 PM   #2 (permalink)
Formerlly Ps933kgt
Vital Velocity's Avatar
Drives: 93 Vr4 / Blown Viper
Trader Rating: (19)
Vital Velocity Level 1Vital Velocity Level 1
Default Re: Houston, Dodge Stealth Turbo parts
Shoot me pictures of the car to psealing@gmail.com
Interested and local
2002 Viper GTS- Intake and Exhaust Work
Vital Velocity is offline   Reply With Quote
Old 09-13-2007, 03:55 PM   #3 (permalink)
Htownstealthttman
Old 09-13-2007, 04:10 PM   #4 (permalink)
Htownstealthttman
Old 09-13-2007, 04:16 PM   #5 (permalink)
Htownstealthttman
Old 09-13-2007, 04:18 PM   #6 (permalink)
Htownstealthttman
Old 09-13-2007, 04:22 PM   #7 (permalink)
Htownstealthttman
Old 09-13-2007, 04:24 PM   #8 (permalink)
Htownstealthttman
sorry the car is dirty, its been sitting for a long time. I still have to put the front wheels back on
Old 09-13-2007, 05:48 PM   #9 (permalink)
Formerlly Ps933kgt
Trader Rating: (19)
ah ok i thought you had just dropped the xcase not the whole tranny from the car
