Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > DFW3S - NT3S - H3S
Old 05-14-2008, 05:26 PM   #1 (permalink)
3s Mechanic
Trader Rating: (14)
rush6432 Level 1rush6432 Level 1
Default Austin 3S Check in...
Just seeing if we cant get a list of all the people in austin. intrested in seeing if we have any newbies.
rush6432 is online now   Reply With Quote
Old 05-14-2008, 06:03 PM   #2 (permalink)
Verified Asian
Sean3S's Avatar
Drives: 94 TT
Trader Rating: (35)
Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7
Default Re: Austin 3S Check in...
Damn Jeff, long time no talk. You got another 3S? lol
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | NGK Coppers & MSD Wires | eK2 EGR Blockoffs | eK2 Fuel Line Loop | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Tein S-Tech Springs | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | VIS Hood
295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04
Collecting Dust - CM Oil Filter, Setrab Oil Cooler, Snow Stage 2 Meth, Brake Lines, Megan Coilovers
Some Day - ABS Delete, Ducting
WTB - ek2 Harness Cover (above the fuel rails)
Sean3S is offline   Reply With Quote
Old 05-14-2008, 06:04 PM   #3 (permalink)
rsuarez1222's Avatar
Drives: 94 3000gt sl
rsuarez1222 is an unknown quantity at this point
im a newb
OBX headers, injen intake, msd wire, ngk plugs, 3SX plenum spacer, Maximum Solid Motor Mounts, fidanza flywheel
rsuarez1222 is offline   Reply With Quote
Old 05-14-2008, 09:25 PM   #4 (permalink)
Drives: 1994 VR4
Trader Rating: (7)
atxvr4 is an unknown quantity at this point
<<<<<<------ Newby here... I'll be back in 3 1/2 more weeks.
On the car:
- Titan Bending TD05 Headers / O2 Housings (8/19/2006)
- TD05 E16G's Braided feeds/returns (03/04/2007)
- DSM SMIC's
- Precision Turbo 680 CC Injectors
- E2K Fuel Loop
- E-Manage Blue w/ ignition Harness
- Custom 3'' exhaust from turbos back (T-Pros DP)
- Magnacore Wires
- 3SX Braided break lines, Carbotech Vented and Slotted Rotors, and Hawk Pads
- SBC-iD III Boost Controller
- K&N FIPK
- Ebay Y-pipe (shinny)
- GTO MR Gears / 5 spd rear end (Installed 07/18/2005)
- RPS Max Street Disc
- 120K and Rod/Main Bearings (Finished 12/16/2005)
- Walbro 255 lph f/p
13C Turbo Track Times (stock fuel):
-13.2 @ 104, 1.86 60' (10.5 PSI - Took out jack/spare/rear and pass seats)
-12.9 @ 106, 1.84 60' (12.3 PSI - slipping clutch, small boost leak, FULL INTERIOR)
atxvr4 is offline   Reply With Quote
Old 05-14-2008, 09:33 PM   #5 (permalink)
Grrrrrr
Madcat's Avatar
Drives: 92 VR-4/2000 cop car
Madcat is an unknown quantity at this point
Im already here fool. Fix my driveshaft.
92 Fiji Blue VR-4
Intake, MBC @ 11 lbs, ATR downpipe, gutted cats, Autopeeter pro comp boost gauge, Defi D Gauge Oil Pressure Gauge. whiteface gauges, vac reduction/egr blockoff, Carbon Fiber hood, big shiny Y pipe, MSD 8.5mm Wires, Maximal Performance solid mounts, Greddy Tyse S Bov , Walbro 255, Optima Red Top, Scanmaster 3
Madcat is offline   Reply With Quote
Old 05-15-2008, 02:36 AM   #6 (permalink)
Yarly.
commodoreredleg's Avatar
Drives: 97 3000GT
commodoreredleg is an unknown quantity at this point
Howdy.
commodoreredleg is offline   Reply With Quote
Old 05-15-2008, 10:15 AM   #7 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: NoCar XCase Test Car
Trader Rating: (22)
AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Still clinging to my spot in the top 10:
DynamicRacing: US 3S Top 10 Fastest List
AdamVR4 is offline   Reply With Quote
Old 05-15-2008, 11:09 AM   #8 (permalink)
pillardsap's Avatar
Drives: 95 Spyder SL
pillardsap is an unknown quantity at this point
I am new and in Austin. I have a white Spyder and a black Sl.
pillardsap is offline   Reply With Quote
Old 05-15-2008, 04:28 PM   #9 (permalink)
3s Mechanic
Trader Rating: (14)
yep, currently trying to figure out how to get it down here cheaply. its in NC right now and shipping quotes im getting are outrageous. i really dont want to drive it either as its low mileage.
Old 05-15-2008, 06:00 PM   #10 (permalink)
Baerdad's Avatar
Drives: 1994 3KGT SL ATX
Baerdad is an unknown quantity at this point
I am a newb - but learning new tricks everyday.
Baerdad is offline   Reply With Quote
