Valve Cover Gasket & Valve Stem Seals - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > 3Si New England Chapter
Old 07-24-2007, 03:05 PM   #1 (permalink)
MaxType 240's Avatar
Drives: '95 VR4/'95 S14
MaxType 240 is an unknown quantity at this point
Feedback Score: 0 reviews
Default Valve Cover Gasket & Valve Stem Seals
Hi all,
I've been burning oil in my VR4 and it's getting embarrising. I notice oil escaping the valve cover so my 1st question is taking the valve cover straight forward? If that doesn't cure the problem, I guess the infamous valve stem seals need work. I read that labor/parts will cost $300-$500?
Thanks for helping,
Jesse
MaxType 240 is offline   Reply With Quote Quick reply to this message
Old 07-24-2007, 06:15 PM   #2 (permalink)
smashbar's Avatar
smashbar is an unknown quantity at this point
Feedback Score: 4 reviews
Default Re: Valve Cover Gasket & Valve Stem Seals
Valve cover gasket replacement is easy... as long as it's the front ones! It's as easy as removing all of the surrounding bolts, and then giving the valve cover a few steady whacks with the old rubber mallet to loosen it/remove it. CLEAN the entire outer channel of the valve cover (remove old gasket, clean groove with paper towels or rags until there's no oil in there), stick the new gasket into the valve cover groove, and replace. Don't forget to change out the 3 spark plug gaskets too... they should come with the valve cover gasket kit. Otherwise, you're likely to eventually develop oil in the spark plug holes once THOSE gaskets wear out.
Good luck. Hope that helped.
smashbar is offline   Reply With Quote Quick reply to this message
Old 07-25-2007, 07:38 AM   #3 (permalink)
Mike Vincent's Avatar
Drives: A 1991 4 bolt VR-4
Mike Vincent is an unknown quantity at this point
Feedback Score: 6 reviews
A bad valve cover gasket could cause oil to drip onto the pipe and make smoke, but if your smoking out of the exhaust, it's definatly not the valve cover gasket.
3Si.org Signiture Picture
Built 4 Bolt, DR3 Heads, Billet DR-900's, Series 2, SCE Center, Quaife, Tien, NT-01's.
91 Mitsubishi VR-4
94 Mitsubishi VR-4
05 Yamaha R1 Raven
Mike Vincent is offline   Reply With Quote Quick reply to this message
Old 07-26-2007, 09:42 AM   #4 (permalink)
Thanks for elaborating smash - I had a feeling there were spark plug gaskets to change out while I was in there.
Mike, the oil is escaping the valve cover onto the exhaust header (front side). With much neglect, the oil probably heated up, put a hole in the exhaust gasket, and gets into the exhaust that way.
I hate neglecting the car this way but my baby girl and 240SX grab all my attention
Jesse
PS - Offer to use Hanscom AFB auto shop is still/always open folks.
'95 240sx: Daily driver, Built KA24DET, GT3071R
'95 VR-4: AWD/TT Winter Sled
Old 07-26-2007, 10:30 AM   #5 (permalink)
CABO BABY!!!
kookie026's Avatar
Drives: 96 RT/TT Forest Grn
kookie026 is an unknown quantity at this point
Feedback Score: 35 reviews
Jesse
Oil will not "leak" into your exhaust through a bad exhaust gasket because the exhaust gas pressure is much greater than atmosphere. If you are blowing smoke out your tail pipe then it is an internal leak; usually either the valve seals or piston rings. Have some one follow you. From a stop start to accelerate normally (no hard accelerating) shifting into second around 4K revs. Repeat this into third. Put the car in Neutral and use only the brakes to stop. If the spotter sees heavy smoke from a start that disapates and then returns to heavy after shifting, you have bad rings. If there is little or no smoke from start but there is a "puff" of heavier smoke when you shift, you have bad valve seals. Also, it will be black or blue smoke, not white. If you have white smoke it is a fuel (usually rich) condition.
96 Stealth RTtt (#32 of 57)
kookie026 is offline   Reply With Quote Quick reply to this message
Old 07-26-2007, 10:34 AM   #6 (permalink)
I'd hate to beleive it Jesse. If it was leaking onto the manifold, it can't get through the gasket and drip into the exhaust. I guess what your saying is that you do have an external leak out of your valve cover. As far as if your smoking out of your exhaust, your looking at a few things.
1. Valve stem seals
2. rings are getting clogged up or damaged
3. PCV is sucking up oil from your heads and into your intake manifold
4. your sucking oil from your rear head into the rear turbo'r rubber intake tube (mine did untill I disconnected the line and put a little breather instead)
5. Turbos/Turbo is blowing some oil into the intercooler pipes, (compressor side) or blowing it right into the exhaust (turbine side)
6. A bad valve guide can do the same thing as a bad valve seal. If the guide isn't sealed perfectly, then your stem seal is ineffective.
Hope this helps you to find your problem.
-Mike
Old 08-08-2007, 09:32 AM   #7 (permalink)
You guys have been really helpful on such a newb topic, thank you both! I'm thinking of selling of it so all I can do to fix her up will help.
Jesse
Old 08-08-2007, 12:53 PM   #8 (permalink)
92Stealth's Avatar
Drives: 99 vette
92Stealth is an unknown quantity at this point
Feedback Score: 8 reviews
mines been leaking oil out of the oil cover itself, the cover you take of the put oil in. it leaks out of that and goes onto the heat shield causing smoke and the burning oil smell, drives me crazy.
92Stealth is offline   Reply With Quote Quick reply to this message
Old 08-08-2007, 01:37 PM   #9 (permalink)
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 is an unknown quantity at this point
Leaking out that cover (filler cap) is not unusual. You can pick up a new filler cap gasket for a few bucks at the dealership and should solve the problem.
'92 VR4 274,000 miles with Big 16G's and all the goodies. Driven daily, 1/4 mile at a time. Once I convinced the wife I needed 600hp to get to work everyday, the rest was easy.
Jeff W
www.xpauto.net
JeffWVR4 is offline   Reply With Quote Quick reply to this message
Old 08-09-2007, 09:37 AM   #10 (permalink)
Leaking out of the oil cap is a sign of blowby as well. With high pan presure, you will also have high valve cover pressure, thus helping the oil to blow through the oil cap seal. The PCV system is only so effecient, and can not compensate for extreme blowby conditions.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
