#12 (permalink) |
Yes Ray Pampena is god! He's down in Long Island. People fly him out to Europe to tune theirs 3S's. I wouldn't let any one else tune my car period. I am sure he could tune your ARC2 and Emanage w/ out a problem.
Parts for sale http://www.3si.org/forum/f4/very-lar...tinued-414853/
http://www.3si.org/forum/f4/very-lar...-stock-414848/ 1998 red 3000 GT-Base bought in 2003 sold in 08 1993 green VR4-Sold 1994 pearl VR4 bought it with 7,400 miles in 06-Sold with only 10,000 miles(1 years tuition at Wentworth Inst. of Tech. =30k)-I still regret it 1992 red Stealth RT/TT... A little something extra |
#13 (permalink) |
hmmmm, interesting. I've got a pretty badass 15g setup myself and couldnt push more than 401awhp / 38x flb running at 19-20psi using Meth....this with an ESP tune. ESP says something with timing cause of the 96 ECU
I need to go see Larry, he says my meth is tapped in the wrong spot hurting me, thinks I can boost higher. What kind of dyno was your numbers on? What was the temp? any correction value? Great numbers
![]() Max Hp: 401.0 @ 6105RPM / 128.4MPH (Mustang Dyno) Max Torque: 385.6 @ 4737RPM / 74.9MPH (Mustang Dyno) Best Track time: 12.211 @ 119.45 (NE Dragway) WPI:Import Best Show | April 2008 ROTM |
#14 (permalink) |
Now someone can correct this if they feel I am wrong but everything I have read leads me to believe Meth nozzles are supposed to be 12-14 inches before the TB. Reason being is for adequate mixing to ensure an even mix which will help the meth cool the charge air more effectively.
So my ? is how far away is the injection point of the meth from your TB? Most likely is not the main factor for your slightly lower numbers. Just trying to help figure out the meth issue you had said you are having. |
#18 (permalink) | |
Just Cruisin'
![]() Did you have a dyno done BEFORE Ray P. tuned it? What were those numbers if so?
95 3KGT/07 350ZR
#19 (permalink) |
Forum user
What is your AFR when you are just crusing ?
Not to old to have fun - yet ??? -
2007 Dodge SRT-8 Superbee 2007 Hemi Quad Cab 4X4 2006 Harley V-Rod , 1999 S&S 1200 Sportster 2005 H/D FatBoy(Stage II),1973 BMW R75/5 restored 2004 Ducati Monster SR2,1972 BMW R75/5 restored 2004 Ford MACH I Mustang, Pro-Charger 535 RWHP 2002 Viper SRT-10,2000 Custom 883 Sportster 1992 Stealth RT TT (Stage III) 633.9 AWHP 1992 Stealth RT 1991 Stealth RT TT ![]() and More |
