Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > 3Si New England Chapter
Old 07-03-2008, 12:27 PM   #1 (permalink)
Quickest rebuild failure.
p2e2t2e2pete's Avatar
Drives: '92 Stealth TT
p2e2t2e2pete Level 1p2e2t2e2pete Level 1
Default Anyone wanna help a kid with a TT?
First off I'm located in Chelmsford Mass, near lowell. I recently rebuilt my 1992 Stealth TT, and I'm having problems getting it to idle properly. It only idles for about 15-20 seconds, then dies. I'm also having either insainely loud lifter tick, or I've spun a bearing. but I've drained the oil twice and found minimal shavings. I would like to try a different ECU to see if it will help the idle. A set of good ears would be nice too, since I have no experience with lifter tick vs. spun bearing.
Thanks alot, Pete.
Some of you may have seen my Epic failure: My Twin Turbo rebuild thread, so you get the idea of what kind of work I have to do now.
Same deal as before though, I have little expereince and would greatly appreciate any wisdom bestowed upon me by my NE3S elders.
p2e2t2e2pete is offline   Reply With Quote
Old 07-03-2008, 12:32 PM   #2 (permalink)
stans3000gt's Avatar
Drives: 1992 VR-4, 1993 SL
stans3000gt Level 2stans3000gt Level 2stans3000gt Level 2
Default Re: Anyone wanna help a kid with a TT?
hey man I can help you out whenever I got some time, As far as ECU I could let you borrow mine sometime when I am not driving the VR-4 or if my dad isnt crusing in it during the weekend. As far as lifter Its pretty obvious I could tell pretty fast....
stans3000gt is offline   Reply With Quote
Old 07-03-2008, 12:34 PM   #3 (permalink)
Oh we could also pull the ECU and check for leaky caps no reason to jump for the ecu replacement right away But I know its tempting to just put another one in there.... Also how is your ECS I hear it can backfire to the ECU and damage it....
Old 07-03-2008, 12:42 PM   #4 (permalink)
ATL
MK_94_3000GT's Avatar
Drives: 1994 3000GT
Trader Rating: (21)
MK_94_3000GT Level 4MK_94_3000GT Level 4MK_94_3000GT Level 4MK_94_3000GT Level 4MK_94_3000GT Level 4
I'm not exactly near you, but I just bought a 93 RT/TT if you need any parts I am parting it out.
MK_94_3000GT is online now   Reply With Quote
Old 07-03-2008, 01:01 PM   #5 (permalink)
For all I know, my ECS is fine. But then again, the car hasn't run in 9 months, and when it did, I only put about 50 miles on it, so I really couldn't say...
Old 07-04-2008, 09:29 AM   #6 (permalink)
And as far as the ECU goes, if somebody has one that I could borrow, I could go just about anywhere in MA to pick it up if necessary. I would only need it for an hour or so....
Old 07-05-2008, 09:40 AM   #7 (permalink)
Drives: 97 VR4
teamafx is an unknown quantity at this point
just sell it to me. i'll fix it
teamafx is offline   Reply With Quote
Old 07-05-2008, 12:51 PM   #8 (permalink)
VA 3S
Tool Man's Avatar
Drives: 94 3000GT NA
Trader Rating: (24)
Tool Man Level 5Tool Man Level 5Tool Man Level 5Tool Man Level 5Tool Man Level 5Tool Man Level 5
He found his problem, washer fell into the intake.
Under the knife for a TT conversion.
Pics of my car, click me!_______ August 2006 ROTM
Tool Man is offline   Reply With Quote
Old 07-05-2008, 01:02 PM   #9 (permalink)
Yeah it did. I had litterally no idea of the problem till I pulled my rear head of at around 4:00 this morning. I'll still probably need an ECU, as I had wanted to swap one in before I rebuilt...
But seeing as how I had VERY shitty compression on 4 out of 6 cylinders, means that and ECU could have only done so much. Fixing my valve seat issues and the washer issue (definitely a noob moment ) should help me out a little I think
Thanks for the offer, but I think I'm going to keep this car
Old 07-05-2008, 02:32 PM   #10 (permalink)
Dec. 2001
TwinTurboKid's Avatar
Drives: 91 & 94 Stealth TT
Trader Rating: (36)
TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7TwinTurboKid Level 7
I have an ECU lying around some where. I'm not to far from you either.
1991 Dodge Stealth R/T Twin Turbo
MODS|ATR Downpipe|HKS Super Dragger|DN Pre Cat Elims|AEM WB02 Gauge|Ek2mfg Fuel Rail Loop|Polished Fuel Rail|Wrinkle Black Intake Mani|Mirror Red Valve Cover|Injector Harness Cover|Ohio Bob Short Throw Shifter|DN Intake Pipes|Palm Datalogger|TD04L 15G Turbos|EGR Block Off Plates|Vac Reduction|Evap Delete|Cruise Control Delete|A/C Delete|Battery Relocated|E2kmfg Poly Mounts|PTE 680 Injectors|Hotwired Walbro 255lph FP|Snow Performance Water/Meth Injection|Tein Coilovers|18x9 Saleen Replicas| 265/35/18 Sumitomo HTR II|New Shortblock|Rebuilt Heads|IPS FMIC|RPS Max Street|AEM EMS|AEM IAT|AEM 3.5 BAR| Next Up: Tuning AEM
1994 Dodge Stealth R/T Twin Turbo Under Construction
TwinTurboKid is offline   Reply With Quote
