Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Michiana Chapter
Old 04-17-2009, 07:41 PM   #1 (permalink)
BLACK STEALTH TT!
AceJas's Avatar
Drives: 93 StealthTT 92 Vr4
Trader Rating: (12)
AceJas is an unknown quantity at this point
Default Anyone Have a Oil cooler in Indianapolis?
Just throwing this out there. If you have or know of a extra oil cooler for a first gen Vr4 let me know. Im getting my short block in a couple days but i cant reuse my old one. Thks Jason
93 Stealth RT TT Black with Black Leather. Engine = Td05 Manifolds and 16'g Evo Turbos,port and polished heads with 1mm oversized valves,99 lifters,High Rev springs+Titanium Retainers,Ips 272 cams,Rebuilt 4 bolt main with forged CRYO'D and polished Crank, forged H-beam rods,Arp studs Arp-2000 Rod bolts,CP Forged Pistons.CX Racing FMIC,Pte 1200cc's running Emanage Ultimate.Hotwired Duel Bosch 044pumps,Oohnoo's fuel Rails.Wideband 02,Mechanical boost Gauge, Hks Eboost controller,Msd wires,Ngk stage 1 colder copper plugs,Dejons No maf pipes,Hks SSQ blow off valve,Aluminum cold air box mated to CF 575 hood,3sx Poly engine Mnts,egr block off,vacume reduction.
Looks = 575 CF hood,3sx stealth cut-thru spark cover,3sx Aluminum shifter trim,3sx Aluminum Twin Turbo pedal covers,Aluminum Stealth Door sills,CF shifter+boot+ebrake,CF ebrake handle cover,3sx CF Full Dash kit,Aluminum Oil cap,18 inch Aluminum rims and lowprofile tires.
Drivetrain = New flywheel,Stage 3 5 puck clutch,25 spline Tranny with CRYO'D output shaft.New 25 spline Transfercase with CRYO'D Case. Ek2 TC Cage OTW.
Exhaust = Td05 Manifolds, 3' Downpipe, 3' Strait Exhaust to duel 6' Cans.
Suspension = Tein S spings.
AceJas is offline   Reply With Quote
Old 04-18-2009, 08:06 PM   #2 (permalink)
rdmelton's Avatar
Drives: 92 Stealth TT,00 WS6
Trader Rating: (38)
rdmelton Level 2rdmelton Level 2rdmelton Level 2rdmelton Level 2
Default Re: Anyone Have a Oil cooler in Indianapolis?
Did you talk to Fred? I'd say there's a good possibility that he has one.
Blue 92 TT - IPS EVO 3 kit, Emanage Ultimate, FMIC, RPS Max clutch, Fidanza flywheel, PTE 680 injectors, AEM tru boost, dyno tune by IPS - 423 awhp at 16 psi, Ground Control Coilovers, 18 x 10 Saleen replica chrome rims with 295/30/18 Kumho Ecsta SPT tires.
My Virtual Garage
rdmelton is offline   Reply With Quote
Old 04-23-2009, 11:05 PM   #3 (permalink)
BLACK STEALTH TT!
AceJas's Avatar
Trader Rating: (12)
Yeah i allways hit fred up first. I ended up buying one from my bud in Michican He has 16 3s cars on his property LOL.
