Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Michigan 3SI
Old 05-01-2008, 02:43 PM   #711 (permalink)
PeaceLova56's Avatar
Drives: 94 3000GT
PeaceLova56 is an unknown quantity at this point
Mitsubishi Re: West MI
Is anyone going to organize a gathering then?
PeaceLova56 is offline   Reply With Quote
Old 05-01-2008, 03:45 PM   #712 (permalink)
jacob666's Avatar
Drives: '91 Stealth ES
jacob666 is an unknown quantity at this point
Default Re: West MI
*West MI '08 BBQ Thread*
Originally Posted by Hannibalzero View Post
The SOHC only blew up after adding oil. I think its pretty clear: new oil = bad, no oil = good.
jacob666 is offline   Reply With Quote
Old 05-02-2008, 05:21 AM   #713 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 is an unknown quantity at this point
Default Re: West MI
Originally Posted by sublime_whatigo View Post
Well its definately not the first car I've seen like that, its not gonna blow up or anything. Technically as long as they are within like 10-15% of eachother your still in spec wether or not its ~170 or ~200. I didnt bust out the calculator but your probably just out of spec.
The spec for NA is 185psi, with a 139psi lower limit. The variation between cylinders should not exceed 14psi.
Jeff W.
Red '92 VR4 211,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, the rest was easy
Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, Home-made Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, Stillen rotors & pads, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi Design wheels, custom 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 05-02-2008, 06:09 AM   #714 (permalink)
One Wheel Wonder
B-Man0660's Avatar
Drives: '92 3000gt SL
B-Man0660 is an unknown quantity at this point
Default Re: West MI
Thanks for chiming in Jeff
15.0009sec@93.00mph 1/4mi
http://www.stealth316.com/2-calc-hp-et-mph.htm <-216hp-269hp according to this.
B-Man0660 is offline   Reply With Quote
Old 05-02-2008, 11:32 AM   #715 (permalink)
MN 3/S Organizer
Curt_Gendron's Avatar
Curt_Gendron is an unknown quantity at this point
Default Re: West MI
You guys in western Michigan should hop across the pond and join us at the Upper Midwest Gathering in a couple of weeks in Wisconsin Dells.
Just pretend its easy getting through Chicago traffic.
Upper Midwest 3/S Gathering 2008
later,
Curt
Curt_Gendron is offline   Reply With Quote
Old 05-02-2008, 11:43 AM   #716 (permalink)
Michiana 3/S Chapter Pres
BrianHag's Avatar
Drives: 2000 Bonneville SSEi
BrianHag Level 3BrianHag Level 3BrianHag Level 3BrianHag Level 3
Default Re: West MI
later,
Curt
It is if you take the ferry across Lake Michigan.....
Michiana3s Will be back soon!!
The trophy is ours!!! 2006 and 2007 Chapter Challenge Champs!!
Some of us are more excited than others....
BrianHag is offline   Reply With Quote
Old 05-02-2008, 12:02 PM   #717 (permalink)
MN 3/S Organizer
Default Re: West MI
Very true. Its only a two hour drive from Milwaukee and a 2.5 hour drive from Manitowoc.
later,
Curt
Old 05-02-2008, 12:47 PM   #718 (permalink)
Hates Gravel
sublime_whatigo's Avatar
Drives: reliable car (nissan
Trader Rating: (21)
sublime_whatigo Level 1sublime_whatigo Level 1
Default Re: West MI
Unfortunately Ill be driving around chicago, I think gas is still cheaper than the ferry.
92 3000GT VR4
Black Wheel Mafia - Member 002
Matt
sublime_whatigo is offline   Reply With Quote
Old 05-13-2008, 02:50 PM   #719 (permalink)
Hates Gravel
Trader Rating: (21)
Default Re: West MI
Wish my car good luck for the trip to UMG for me guys. Well catch u guys later!
Old 05-13-2008, 03:53 PM   #720 (permalink)
jacob666's Avatar
Default Re: West MI
i'll rub my rabbit's foot for you... wait she kicks back NM!
