Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Michigan 3SI
Old 04-16-2008, 03:22 PM   #641 (permalink)
Hates Gravel
sublime_whatigo's Avatar
Drives: reliable car (nissan
Trader Rating: (22)
sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7
Default Re: West MI
Originally Posted by motomaniac06 View Post
its a 92rt tt that im working on , but i also have a 94 vr4 and a 92rt tt parts car
Good to hear, Im on #5 of parts car I think. You dont know the guy on here named "bookeditar" do you, he hasnt been around much lately but he used to have a parts car and a TT of some kind. Lived in holland also, I think I met him once.
Oh and if your up for it I'll probably do another 3S BBQ at my house, it was a pretty good turn out last year.
92 3000GT VR4
Black Wheel Mafia - Member 002
Matt
sublime_whatigo is offline   Reply With Quote
Old 04-16-2008, 03:37 PM   #642 (permalink)
clean your car
gg3000gt's Avatar
Drives: 92 3000gt n/a
gg3000gt is an unknown quantity at this point
Default Re: West MI
had a great time last, year hopefuly u will do it agian
gg3000gt is offline   Reply With Quote
Old 04-16-2008, 03:40 PM   #643 (permalink)
SPEED FREAK
motomaniac06's Avatar
Drives: 94' vr4
motomaniac06 is an unknown quantity at this point
Default Re: West MI
i do know of a few guy in holland that owned 3s's but dont know if they were on here. yea, ide probably be up for that bbq i wouldnt mind meeting some of the people that post here.
motomaniac06 is offline   Reply With Quote
Old 04-16-2008, 04:41 PM   #644 (permalink)
Verified Eagle Scout
jacob666's Avatar
Drives: '91 "GT", '91 R/t
Trader Rating: (7)
jacob666 Level 5jacob666 Level 5jacob666 Level 5jacob666 Level 5jacob666 Level 5jacob666 Level 5
Default Re: West MI
SOS matt lol. Well anyone that can help.
So I pulled both valve covers to replace the gaskets. I'm just casually inspecting my heads and um ya about that! I believe its called a rocker arm is missing on my rear bank middle cylinder.
this thing:
where do I go from here, where can I get one, how do i replace it, and do i have the tools???! lol
Looking for 1g dohc n/a engine, PM if you have one or know where I can get one
**Aluminum Engine Dress-up Kits For Sale**
jacob666 is offline   Reply With Quote
Old 04-16-2008, 04:53 PM   #645 (permalink)
Hates Gravel
Trader Rating: (22)
Default Re: West MI
this thing:
Wow, you sure its not hiding in the head somewhere? Makes me wonder if that motor had jumped timing in the past. Very odd, I never had that valve cover off before so dont look at me If it has jumped time before that valve is bent, do a compression test on that cylinder before you do anything, if compression is good then you can replace it, also compression test afterwards to make sure.
Well you can get it my shed, lol. And since you probably dont want to pull the timing belt off to do it.... you have to compress the valve spring, ive done it before with a screwdriver but I dont reccomend it.
Search for homemade valve spring compressor and you can make a tool for cheap. Should make your car run a little healthier with that, hehe.
edit. dsm's also use that rocker, not positive that all of them did.
Old 04-16-2008, 09:25 PM   #646 (permalink)
SPEED FREAK
Drives: 94' vr4
Default Re: West MI
sublime, do you have a myspace? i have a few questions about the tb not sure if you can anwser them, but i have some pics on my -space w/ explainations (dont know how to post pics on here yet)
Old 04-16-2008, 10:57 PM   #647 (permalink)
jacob666's Avatar
Trader Rating: (7)
Default Re: West MI
myspace.com/ his screen name.
now to Matt:
sry if you wanted to remain inconspicuous
and ok so let me get this straight.
Step 1: Compression Test
Step 2: build or somehow acquire compressor for valve spring
Step 3: get rocker from you?
Could this be causing my hard starts and/or my 17.7 1/4 mile? lol
Also if it doesn't have good compression, then what?
and ya i had never pulled the cover either, i had taken the plenum to replace the plugs but never took that off. probably a good thing i did tho that and the gaskets i had to scrape off lol
*edit* also do I need to put the plenum valve covers and everything back on to do a compression test?
Old 04-17-2008, 04:03 AM   #648 (permalink)
I'm a Troll
B-Rad's Avatar
Drives: 94' Vr-4
B-Rad is an unknown quantity at this point
Default Re: West MI
Matt. I'm down for another BBQ. Anyone else?
B-Rad is offline   Reply With Quote
Old 04-17-2008, 05:48 AM   #649 (permalink)
jacob666's Avatar
Trader Rating: (7)
Default Re: West MI
+1
And I might bring a clan of ES's with me possibly up to 7 es's lol but we'll have to see.
Old 04-17-2008, 01:31 PM   #650 (permalink)
Hates Gravel
Trader Rating: (22)
Default Re: West MI
+1
7 wow.
For your rocker though, you got the order down. Normally you take off the whole cam to do it but thats a lot of extra work. Look at the pics some people have up on 3si about the homemade tool. You should easily be able to figure it out, just dont compress the spring any farther than you have to or the keepers for the valve spring could fly out.
You can go ahead and do a compression test with it all apart just pull the ecu fuse so the car doesnt try and start. If you have bad compression then that valve may be bent and the head would have to come off.
If you have fine compression I dont know how much of a difference you'll notice as you have 1 other intake or exhaust valve that works fine yet, but it will help some.
