Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Michigan 3SI
Old 04-11-2008, 12:35 PM   #621 (permalink)
Male Driver
Mychal1216km's Avatar
Drives: 94 Mitsu 3000GT
Mychal1216km is an unknown quantity at this point
Default Re: West MI
Originally Posted by sublime_whatigo View Post
I need a cheap stealth for a DD, I hate my Taurus with a passion.
I had a Taurus before my 3000GT, hated it.
But I have to say my grandpa is awesome I was telling him how much it was for those stupid mitsu tools for the timing belt change. So what does he do....
Made me an amazing working end yoke holder!!
Keyten
Originally Posted by jeettao View Post
It has maximum acceleration and top speed. And is rated to "800 Horse" or 1 unicorn.
http://i23.tinypic.com/j0fki1.gif
Mychal1216km is offline   Reply With Quote
Old 04-11-2008, 01:26 PM   #622 (permalink)
Hates Gravel
sublime_whatigo's Avatar
Drives: reliable car (nissan
Trader Rating: (21)
sublime_whatigo Level 1sublime_whatigo Level 1
Default Re: West MI
Thats bad-a, should work way better than my oem mitsu one too. Honestly I was just gonna show you a few tricks where you dont even need that tool, but it doesnt matter now. Just let me know when you need that tensioner spanner wrench.
92 3000GT VR4
Black Wheel Mafia - Member 002
Matt
sublime_whatigo is offline   Reply With Quote
Old 04-11-2008, 04:30 PM   #623 (permalink)
Male Driver
Default Re: West MI
I put the pulley back on and the tensioner pin has to be pulled is there suppose to be no tension at all or can there be a lil force when i pull the pin out...cause idk why i need that tension spanner cause i seem to have enough tension unless i pull the pin and it screws up??
Old 04-12-2008, 08:14 AM   #624 (permalink)
Hates Gravel
Trader Rating: (21)
Default Re: West MI
There should be no force when you pull the pin, its a very fine line and is very hard to get perfect but its not absouletely necessary. I dont see how you could have even close to the right amount of tension without rotating the pulley though.
The 2 holes should be close to the top of the pulley and horizontal. After you pull the pin you should be able to rotate the engine around and then be able to put the pin back in if you did it perfectly.
Old 04-12-2008, 10:14 PM   #625 (permalink)
Male Driver
Default Re: West MI
Yup got all of that, I can put the pin back in just have to give it a lil bit of force to get it in but it will go in
Old 04-13-2008, 07:43 AM   #626 (permalink)
Hates Gravel
Trader Rating: (21)
Default Re: West MI
You should be fine then, what did you use to roatate that pulley?
Old 04-13-2008, 08:57 AM   #627 (permalink)
Male Driver
Default Re: West MI
I let it rotate itself until what it looked like in the pictures and tightened it down and it didnt rotate on me.
Old 04-13-2008, 04:52 PM   #628 (permalink)
Male Driver
Default Re: West MI
Looks like I have to send my car to a shop, I broke a bolt off in my oil pump. I don't have the time to do the oil pump myself rignt now, I guess the shop gets some of my money now
Old 04-13-2008, 05:50 PM   #629 (permalink)
Hates Gravel
Trader Rating: (21)
Default Re: West MI
What bolt did you break? Hopefully not the hydraulic tensioner one, that goes into the block not the oil pump. Good luck though.
Old 04-13-2008, 09:59 PM   #630 (permalink)
SPEED FREAK
motomaniac06's Avatar
Drives: 94' vr4
motomaniac06 is an unknown quantity at this point
Default Re: West MI
Originally Posted by jacob666 View Post
sweet, as a rough estimate lets plan for mid May... just for the time being, as it gets closer we can make more specific.
just about have the car all togather! by the middle of the week i hope to have it on the road. we might have to make that trip a little sooner.
motomaniac06 is offline   Reply With Quote
