Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Michigan 3SI
Old 01-31-2008, 05:23 AM   #561 (permalink)
Male Driver
Mychal1216km's Avatar
Drives: 94 Mitsu 3000GT
Mychal1216km is an unknown quantity at this point
Default Re: West MI
I have no pressure behind my clutch pedal in the 3000GT, should I try to bleed the lines or is it automatically the master cylinder??
Keyten
Originally Posted by jeettao View Post
It has maximum acceleration and top speed. And is rated to "800 Horse" or 1 unicorn.
http://i23.tinypic.com/j0fki1.gif
Mychal1216km is offline   Reply With Quote
Old 01-31-2008, 05:36 AM   #562 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6
Default Re: West MI
It's not automatically anything. I'd recommend looking to if there's a leak somewhere first (master cyl, slave cyl, clutch hose). Then fix whatever's leaking and bleed the lines.
Jeff W.
Red '92 VR4 213,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Finally on the road again after the broken rod mod at NG!!!
Big 16G Turbos w/IPS headers and pre-cat eliminators, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS Stage 5 clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PowerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 01-31-2008, 11:41 AM   #563 (permalink)
Verified Eagle Scout
jacob666's Avatar
Drives: '91 "GT", '91 R/t
Trader Rating: (7)
jacob666 Level 5jacob666 Level 5jacob666 Level 5jacob666 Level 5jacob666 Level 5jacob666 Level 5
Default Re: West MI
guys guys, just a reminder 3SFOC/TC Gators 5th Anniversary meet in less then a week!
Lets do this guys!
We have three so far from this side, lets show em how many we really have hehe. I'm going to be driving over Wednesday noon/afternoon and I have room for one, maybe two if you want to catch a ride with me.
5th Anniversary 3SFOC/Gators Gathering Feb 6.
jacob666 is offline   Reply With Quote
Old 01-31-2008, 01:27 PM   #564 (permalink)
dodgemystealth92es's Avatar
Drives: dodge stealth es
dodgemystealth92es Negative 1
Default Re: West MI
hey hows everyone been? anything new? my laptop took a shit so ive been mia for a while... if anyones interested im having a super bowl party at my house in comstock park, maybe any of you could stop out.
dodgemystealth92es is offline   Reply With Quote
Old 01-31-2008, 02:38 PM   #565 (permalink)
Male Driver
Default Re: West MI
It's been sitting outside all winter and I haven't driven it or started it in about 2 weeks, so I won't be able to see anything on the ground. Would bleeding the lines let me know if there is a leak?
Old 01-31-2008, 03:40 PM   #566 (permalink)
NG09: The Comeback Tour
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7
Default Re: West MI
West siders don't forget the Lansing meet on Fed 24. Lansing Gathering - 2/24/08
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress
Custom 12x18 poster/photo prints
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 01-31-2008, 05:30 PM   #567 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Default Re: West MI
Actually, you might not see anything leaking on the ground even if you could.
First, check the reservoir and see if it's low. If so, you've got a leak. Then check under the carpet on the driver's side and see if fluid has leaked down the firewall and under the carpet. If so, your Master Cylinder is leaking. If not, look down on top of the tranny and see if you have any fluid puddled up in the area under the slave cylinder. If so, either the slave cylinder or hose is leaking. if the hose is leaking, you'll see fluid on the hose. Then replace whatever parts are leaking and bleed the system.
Old 02-03-2008, 03:13 PM   #568 (permalink)
One Wheel Wonder
B-Man0660's Avatar
Drives: '92 3000gt SL
B-Man0660 Level 1B-Man0660 Level 1
Default Re: West MI
Hey Jacob, I don't need a ride to 3SFOC/TC Gators 5th Anniversary meet, but I will be there.
15.0009sec@93.00mph 1/4mi
http://www.stealth316.com/2-calc-hp-et-mph.htm <-216hp-269hp according to this.
B-Man0660 is offline   Reply With Quote
Old 02-03-2008, 08:59 PM   #569 (permalink)
jacob666's Avatar
Trader Rating: (7)
Default Re: West MI
Right ok thanx for the heads up Bryan. Seeya there!
Old 02-07-2008, 03:33 PM   #570 (permalink)
Male Driver
Default Re: West MI
Ok, so I do have a leak and I have read it is a good thing to replace both the master and slave cylinders. Is it safer to buy totally new or rebuild kits (if I can actually rebuild them myself in my garage with minimal tools) for cheap, and what else is needed besides the cylinders are there hoses that I should buy too?
It looks like I will be buying them from Rock Auto since they look to be cheap on the parts, if you could look there to see if everything there is ok to buy and which is best.
Thanks
