#713 (permalink) | |
Certified Car Nut
Jeff W.
Red '92 VR4 211,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, the rest was easy ![]() Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, Home-made Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, Stillen rotors & pads, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi Design wheels, custom 2-tone all-leather Interior. |
#714 (permalink) |
One Wheel Wonder
Thanks for chiming in Jeff
![]() 15.0009sec@93.00mph 1/4mi http://www.stealth316.com/2-calc-hp-et-mph.htm <-216hp-269hp according to this. |
#715 (permalink) |
MN 3/S Organizer
You guys in western Michigan should hop across the pond and join us at the Upper Midwest Gathering in a couple of weeks in Wisconsin Dells.
Just pretend its easy getting through Chicago traffic. ![]() Upper Midwest 3/S Gathering 2008 later, Curt |
#716 (permalink) | |
Michiana 3/S Chapter Pres
Michiana3s Will be back soon!! The trophy is ours!!! 2006 and 2007 Chapter Challenge Champs!! ![]() Some of us are more excited than others.... |
| Thread Tools | |
