Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Michigan 3SI
Old 05-06-2008, 08:01 AM   #21 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 is an unknown quantity at this point
Default Re: need a mechanic neer holland MI
Originally Posted by kyleh18 View Post
Ok well its official. just got off the phone and the f***ing valves are bad. needs rebuild. let me know if any of you can do it. Let me know if any of you would be willing to do this and if you could give me some kind of quote for a price and what i would need for tools. I have a warehouse in wyoming Grand Rapids on 28th st. if anyone can do it. let me know thanks
Are you going to do a full rebuild with rings and bearings, or just an upper (heads) rebuild?
JeffWVR4 is offline   Reply With Quote
Old 05-06-2008, 08:14 AM   #22 (permalink)
Certified Car Nut
JeffWVR4's Avatar
A full rebuild will cost ~$1200 in parts (including some valves), ~$400 at the machine shop, and $1900+ in labor. With the right tools and know-how, it's about a 35 hour job on a NA. And those prices assume the crank. pistons, and cylinders bores are all ok.
Old 05-06-2008, 02:10 PM   #23 (permalink)
One Wheel Wonder
B-Man0660's Avatar
Drives: '92 3000gt SL
B-Man0660 is an unknown quantity at this point
35 hrs to do it right. (cringes at flashbacks of TJs n/a)
15.0009sec@93.00mph 1/4mi
http://www.stealth316.com/2-calc-hp-et-mph.htm <-216hp-269hp according to this.
B-Man0660 is offline   Reply With Quote
Old 05-06-2008, 07:33 PM   #24 (permalink)
Helder 3k
Drives: 93 3000gt base
kyleh18 is an unknown quantity at this point
I dont know exactly what i need or what i would rebuild but this mechanic said he will do it for a maximum of 1900$. should i just go ahead and have them deal with it? from what this sounds is like that sounds like a good price. let me know guys. thanks
kyleh18 is offline   Reply With Quote
Old 05-06-2008, 07:39 PM   #25 (permalink)
Hates Gravel
sublime_whatigo's Avatar
Drives: reliable car (nissan
Trader Rating: (21)
sublime_whatigo Level 1sublime_whatigo Level 1
You should do a little research and find out exactly what he is replacing, and #1 make sure he is using mitsu parts for the timing components at the very least. Ive done turbo car rebuilds for 700 only labor fyi.
92 3000GT VR4
Black Wheel Mafia - Member 002
Matt
sublime_whatigo is offline   Reply With Quote
Old 05-06-2008, 08:01 PM   #26 (permalink)
Helder 3k
let me know if any of you guys would want to take this job or if the mechanic is the best way to go. i also was wondeirng are there any internal upgrades i should do while doing this? thanks again
Old 05-07-2008, 06:32 AM   #27 (permalink)
Certified Car Nut
JeffWVR4's Avatar
For that price, he's probably pulling the head(s), with the engine still in the car (difficult, but doable), and replacing only the bent valves, head gaskets, timing belt, and tensioner(s). Nothing to the bottom end or internals. I'm just guessing though. Curious to find out.
Jeff W.
Red '92 VR4 211,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, the rest was easy
Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, Home-made Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, Stillen rotors & pads, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi Design wheels, custom 2-tone all-leather Interior.
Old 05-07-2008, 07:09 AM   #28 (permalink)
Helder 3k
would you recomend doing something different than that ^^ when doing this project?
Old 05-07-2008, 09:16 AM   #29 (permalink)
SPEED FREAK
motomaniac06's Avatar
Drives: 94' vr4
motomaniac06 is an unknown quantity at this point
Originally Posted by PeaceLova56 View Post
i'd definetly go to a meeting at the state park...
ill have to meet up w/ you guys some time. i think i saw u yester day by wesco on lakewood blvd. i was filling up my stealth.
motomaniac06 is offline   Reply With Quote
Old 05-07-2008, 09:32 AM   #30 (permalink)
One Wheel Wonder
B-Man0660's Avatar
I'd do the whole 120K. See exactly what that mechanic is planning on doing. I feel he's trying to screw you over. If Matt could find the time to do it for you, that'd probably be your best bet. You need to decide what you want done before we can give you a ballpark price. I could probably do it in a couple weekends.
My suggestions:
rebuild heads (replace valves, new VSS, big bore lifters if you have the money)
check the pistons, if they're ok, leave the bottom end alone
do a 120K
