Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Michigan 3SI
Old 05-02-2008, 07:37 AM   #11 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 is an unknown quantity at this point
Default Re: need a mechanic neer holland MI
If you figure $100 for the timing belt, $100 for the hydraulic tensioner, and $50 for the tensioner pully, plus $400 labor, that's about right, if not a little low on the labor. But that wouldn't include water pump, idler pulley or anything else. And if it does turn out you bent some valves, you'll be able to re-use the new parts, but you'll be out on the labor because it will have to be done all over agaiin, and more.
Jeff W.
Red '92 VR4 211,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, the rest was easy
Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, Home-made Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, Stillen rotors & pads, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi Design wheels, custom 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 05-02-2008, 07:37 AM   #12 (permalink)
Helder 3k
Drives: 93 3000gt base
kyleh18 is an unknown quantity at this point
whats a good 120k need?
this is what 3sx says to do
This DOHC bundle includes the water pump and gaskets, timing belt, timing belt hydraulic tensioner, timing tensioner pulley, and the tensioner pulley tool youll need when installing the timing belt.
and they charge 400 for everything
kyleh18 is offline   Reply With Quote
Old 05-02-2008, 07:37 AM   #13 (permalink)
One Wheel Wonder
B-Man0660's Avatar
Drives: '92 3000gt SL
B-Man0660 is an unknown quantity at this point
That stuff you listed is part of a 60K. A 120K includes the oil pump. Depending on the milliage, I'd suggest the 120K. If the teeth on the belt stripped off, it's just as likely you bent valves in which case your heads will need to be rebuild. Usually the pistons are decent and usable. It really wouldn't be too bad to rebuild the heads and do a 120K on the motor. If you have a really high millage motor, just rebuild the whole thing. There are a few of us in the area that can do this. If you want to go with a 3.5L engine, you're gonna have to talk to John Monnin (iirc). He's not too far away and is one of the originals to the 3.5L swap.
Originally Posted by kyleh18 View Post
650 for timing belt, tensioner pully, water pump.. it sounded like he was going to do a full recomended 120 on it. The timing belt didnt actually snap. It was still on the pullys when i took off the cover, but there were rubber shavings all over and the teeth were ripped off the belt. All i can do is hope but if the motor is bad....wtf am i gunna do? is it smarter to repair the motor? buy a new one? part out the car(which i dont think i can do... its my baby and she is beautiful)
what do you guys think? or....
i could make it a 3.1/3.5 liter? that would be bad ass but i need to learn a lot more about the mechanics of these cars before i can jump in and do that or i could pay one of you guys to help me with it....
i dont know well see and ill keep posted on how shes doing.
thanks
15.0009sec@93.00mph 1/4mi
http://www.stealth316.com/2-calc-hp-et-mph.htm <-216hp-269hp according to this.
B-Man0660 is offline   Reply With Quote
Old 05-02-2008, 07:41 AM   #14 (permalink)
One Wheel Wonder
B-Man0660's Avatar
120K includes tensioner, pulley, oil pump, water pump, timing belt, and gaskets. If you have one of us do it, we'll already have the timing tensioner tool. What you're looking at sounds like a 60K, which is a 120K w/o the oil pump basically.
Old 05-02-2008, 10:19 PM   #15 (permalink)
Helder 3k
i have 115k on my car and my water pump was starting to go out and i was JUST about to take it in to do the whole 120k. I dorve it an extra 10 miles when i didnt have to and thats when this whole thing happened. shitty timing but hopefully everything will be ok.
how hard is it to get to the oil pump?
Old 05-03-2008, 08:27 AM   #16 (permalink)
Hates Gravel
sublime_whatigo's Avatar
Drives: reliable car (nissan
Trader Rating: (21)
sublime_whatigo Level 1sublime_whatigo Level 1
Pull all the timing stuff off then pull the oil pan its right there.
92 3000GT VR4
Black Wheel Mafia - Member 002
Matt
sublime_whatigo is offline   Reply With Quote
Old 05-05-2008, 05:22 AM   #17 (permalink)
Certified Car Nut
JeffWVR4's Avatar
And the downpipe, and the starter, and the two tranny brackets, and the flywheel dust shield before you can drop the oil pan. Then there's the AC compressor, the AC bracket, and the oil filter housing bracket before you can remove the oil filter housing.
Old 05-05-2008, 05:43 AM   #18 (permalink)
One Wheel Wonder
B-Man0660's Avatar
Remember Jeff, on an n/a you don't have to pull the a/c bracket
Old 05-05-2008, 05:51 AM   #19 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Isn't there a small bracket that secures the oil filter housing to the block? And if so, isn't it cover up by the AC bracket?
Edit: Wait, I just finished rebuilding a NA engine, so I should be able to remember this, but I don't. That oil filter housing bracket is only on TT engines right? If that's the case, then you don't have to pull the AC compressor and bracket.
Old 05-06-2008, 07:37 AM   #20 (permalink)
Helder 3k
Ok well its official. just got off the phone and the f***ing valves are bad. needs rebuild. let me know if any of you can do it. Let me know if any of you would be willing to do this and if you could give me some kind of quote for a price and what i would need for tools. I have a warehouse in wyoming Grand Rapids on 28th st. if anyone can do it. let me know thanks
