Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Michigan 3SI
Old 07-11-2008, 08:43 AM   #1 (permalink)
Supporting Vendor
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 is an unknown quantity at this point
Default Looking for an Engine Block
In anticipation of possibly needing to replace my engine block, I'm putting
out my feelers for a block and girdle set. I'd prefer a 2-bolt block, but
can go with a 4-bolt block if need be. If it's a 4-bolt block, I may be
interested in the oil pan too.The cylinders do not need to be in great
shape, as long as they can be bored out to 92mm and be good. The girdle and
main bearing journals must be in good condition with no rust. I don't need
any internals. Please let me know if you have something and what you'd want
for it. I'm hoping to find something locally (SE MI area) that I can pick up and avoid outrageous shipping costs. You can PM or e-mail me privately if you wish.
Thanks. And thanks to those who have already responded. I hope to be able to make a decision over the weekend.
Jeff W.
Jeff W.
Xccelerated Performance Automotive
www.xpauto.net
Red '92 VR4 228,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Big 16G Turbos w/IPS headers and pre-cat eliminators, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS Stage 5 clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PowerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 07-11-2008, 05:06 PM   #2 (permalink)
Drives: '96 3000GT N/A
Cheston is an unknown quantity at this point
Default Re: Looking for an Engine Block
Hey not sure if this helps, bc I am not really a mechanic and don't know exactly what you need, but it looks like this guy has ALOT of stuff, and he's in your area. Hope this helps! 3000GT Stealth Parts, lots of Stuff!!!
Cheston is offline   Reply With Quote
Old 07-11-2008, 07:29 PM   #3 (permalink)
Drives: 95rt/tt, suzuki
95 RT/TT is an unknown quantity at this point
hay jeff i maybe selling my 4 blot and on the 7/13 i'm going out to see what josh has. last post
95 RT/TT is offline   Reply With Quote
Old 07-11-2008, 08:40 PM   #4 (permalink)
vyper1's Avatar
Drives: 94 Stealth
vyper1 is an unknown quantity at this point
i have a 92 NA full block u can have for cheap it ran swaped the motor for the tt pm me if you want it let me know
vyper1 is offline   Reply With Quote
Old 07-11-2008, 11:12 PM   #5 (permalink)
Its Z06 Time now...
SneekyTT's Avatar
Drives: 1991 Stealth RT TT
Trader Rating: (11)
SneekyTT is an unknown quantity at this point
I am pretty sure I have an extra 2bolt block sitting around... no internals, but has the girdle.
I live in Chicago suburbs... so if you're interested I could probably meet you somewhere maybe Indiana? I don't know how far you are from South Bend, but I know they have a great Hooters there. If you're interested, $50 for the block plus we could work something out for gas or what not.
Rolls are for fat bitches... Ya dig?!?
-2001 Chevy Corvette Z06 - 12.30@114 1.75 60ft BONE STOCK
SneekyTT is offline   Reply With Quote
Old 07-14-2008, 12:08 PM   #6 (permalink)
Supporting Vendor
JeffWVR4's Avatar
Thanks to all who replied! I picked up a block over the weekend, and it's at the machien shop now to be cleaned and punched. Hopefully it checks out ok.
Thanks again.
