Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Michigan 3SI
Old 02-19-2008, 07:32 AM   #11 (permalink)
umm...yea?
B-Rad's Avatar
Drives: 94' Vr-4
B-Rad is an unknown quantity at this point
Default Re: Higher Octane Pump Gas
I order 110 octane by the drum. Ups freight charge is 65$ on the drum but it works out to being only 2.15$ a gallon + the 65 in shipping so...like 3.17/gallon with shipping.
98' New Zealand Green 3000GT VR4 - Sold
94' Panama Green 3000GT VR4. New Set-up to come
Special Thanks to: GT Pro Performance, Disturbing Motorsports
B-Rad is offline   Reply With Quote
Old 02-23-2008, 08:42 PM   #12 (permalink)
Valarie, 95 VR4
natasreficul's Avatar
Drives: 95 3000GT VR4
natasreficul is an unknown quantity at this point
Where do you order it from?
How many gallons in a drum? By the math right there I'm getting 63-64 gallons.
BPU so far. K&N Intake, Hallman Pro MBC at 14 psi, GReddy type RS BOV, Tanabe Downpipe, IPS Quadtip Cat-back, Gutted Rear Precat, Y-Pipe, Prosport EGT and Boost Gauges in Dual Pillar Cianci Pod
Daily Driver: 94 Dodge Intrepid ES XXXXXX Stolen from a grocery store in mid evening
91 R/T Stealth (loaner car from brother)
natasreficul is offline   Reply With Quote
Old 02-26-2008, 04:08 AM   #13 (permalink)
umm...yea?
B-Rad's Avatar
Drives: 94' Vr-4
55 Gallons to a drum. My math is off. 119.35/55= 2.17 + 65/55 = 1.18 = so...2.17+1.18 = 3.35/gallon
My bad.
Old 02-26-2008, 01:52 PM   #14 (permalink)
Valarie, 95 VR4
My bad.
That's alright, where do you order it from?
Old 03-03-2008, 08:26 AM   #15 (permalink)
umm...yea?
B-Rad's Avatar
Drives: 94' Vr-4
Pure power out of kentucky
Old 03-08-2008, 08:43 PM   #16 (permalink)
Valarie, 95 VR4
***Update***
To anyone who glanced at this thread and was interested.
It's closer to my location, and it may be closer to yours as well:
There is a "Fast Track" gas station located at 13/Mound on the south/west corner that sells 110 Octane Leaded Pump Gasoline.
I did confirm the Speedway location mentioned at 15/Rochester, which has 100 octane unleaded pump.
Surprisingly both of these locations and the fuels mentioned were about the same price. The 100 Octane was listed at ~$5.70 per gallon while the 110 at the Fast Track was ~$5.50 per gallon, today, on 03/08/08.
Just in case anyone was interested.
Old 03-24-2008, 11:28 AM   #17 (permalink)
Bigaddie21's Avatar
Drives: 1992 vr4
Bigaddie21 is an unknown quantity at this point
This might be a stupid question but why cant you put high octane gas from the pump?
Bigaddie21 is offline   Reply With Quote
Old 03-24-2008, 11:47 AM   #18 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 Level 3JeffWVR4 Level 3JeffWVR4 Level 3JeffWVR4 Level 3
Pump gas is unleaded. The higher octane fuels (105+) are usually leaded. It is illegal to dispense leaded gas from the pump directly into the car unless at a race track (the exception may be if it's on a trailor).
Jeff W.
Red '92 VR4 213,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Currently has the broken rod mod.
Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PwerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 04-07-2008, 02:47 PM   #19 (permalink)
Paid Member
MadgwickTT's Avatar
Drives: 94 Stealth TT
MadgwickTT Level 2MadgwickTT Level 2MadgwickTT Level 2
Yeah the asshole at the gas station always comes out screaming when i put 110 directly into my car i just laugh and say to late hahahah
1994 Stealth RT/TT
Black/Yellow Two-Tone UD Pully, Blitz DSBC Spec-R, Stillen DP, K&N filter, Hotwired 255LPH Fuel Pump.
MadgwickTT is offline   Reply With Quote
Old 04-14-2008, 11:01 PM   #20 (permalink)
Valarie, 95 VR4
Also saw a Marathon station at 23/Gratiot that sells 110 leaded octane, was $6 a gallon.
