#1 (permalink) |
Hitokiri Battousai
For those that go - you already know what it is.
For those that don't: http://www.mi3si.org/gatherings/events.php?neventid=27
#3 (permalink) |
Certified Car Nut
IT still goes on. Every Wednesday night from 4:30 until.... You can come and go as you please, so you don't have to be there by a certain time.
Jeff W.
Red '92 VR4 211,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, the rest was easy ![]() Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, Home-made Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, Stillen rotors & pads, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi Design wheels, custom 2-tone all-leather Interior. |
#7 (permalink) |
Certified Car Nut
Welcome aboard! And yes you're absolutely welcome to join us. We usually sit at the large table next to the bowling and golf game machines about halfway back into the place near the pool tables. If you're not sure, just say "3SI", and when we respond, you'll know you're in the right place ;-)
