Go Back   3000GT/Stealth International Message Center > Regional Discussions > Chapters > Arkansas 3000GT/Stealth
Old 11-14-2007, 11:38 PM   #11 (permalink)
BMFRU2's Avatar
Drives: DODGE STEALTH TT
BMFRU2 is an unknown quantity at this point
Default Re: AEM Brains
Originally Posted by eyeluvmy3kgt View Post
john (jwetzler) got a new ecu at autozone for a really good price. you could sell the aem and throw a stock ecu back in and buy an afc and still come out ahead.
As far as plug and play. an SAFC or maft are as easy as it gets. If you still have stock injectors you will have them set to ZERO. You will only need one once you upgrade to larger injectors.
I want to get ALL the electrical replacements out of the way. But the auto zone advice is well received. I can due 4 a back up CPU. I think that my CAS is bad. That might explain the cranking but no start. Plugs and wires are good. So is the ISO. Will replace PTU, Coils an Capasitor just B/C. Oh yes, I still have stock inj.
BMFRU2 is offline   Reply With Quote
Old 11-15-2007, 06:45 AM   #12 (permalink)
500hp daily driver
eyeluvmy3kgt's Avatar
Drives: a 17 year old VR4
Trader Rating: (15)
eyeluvmy3kgt is an unknown quantity at this point
once you get a stock ecu back in there you will be able to read the check engine light and see whats wrong.
-Marshall
'91 VR-4 one of 293
Check out My Pics and "The Story of My Car" UPDATED 10/23/2007 with engine rebuild
Engine rebuild: Done! 8/07
Paint: Done! 11/07
Mods:
Wiseco +0.055" pistons, DR650R turbos, PTE 550cc injectors, Denso 310lph FP, Aeromotive AFPR w/ custom fuel lines, FP Hotwire, ATR downpipe, ATR catback, HKS SSQV, Apexi SAF-C, Apexi AVC-R, Apexi S-ITC, PST 2pc. CFDS, TEIN S spings, Fidanza flywheel, ACT clutch, Magnecore wires, 3SX control arms, speed bleeders, battery relocation, OZ Superleggera 18x9 wheels, Stewart Warner FP gauge, Scanmaster 3, MMcd, Kormex Tranny & T-case, Corbeau seats,
'92 Pearl White VR4 - Dad's ride
-mint condition, tein coilovers, racing hart wheels, hks IC's, tenabe exhast
18 spline t-case for sale $225 shipped FIRM. PM me
eyeluvmy3kgt is offline   Reply With Quote
Old 01-08-2008, 04:48 AM   #13 (permalink)
BMFRU2's Avatar
Been off site 4 a while (as U can c). Just taking my time 2 get the parts in right Next an ECU, a good Battery, then AFT. But 1st I'll check the MFI and C voltage across pin 7 to 13. If 0-3v, then MFI is OK. If more than 7v Bad.
Old 01-09-2008, 11:15 AM   #14 (permalink)
91 Stealth TT
jwetzler's Avatar
Drives: 91 Stealth TT
Trader Rating: (6)
jwetzler is an unknown quantity at this point
Make sure you don't have any blown fuses. I blew Fuse 12 on the drivers side kick-panel area. With that fuse blown, my car would crank but would never actually fire up.
Also you can pull a spark plug wire and touch it to ground and see if you are getting any spark when you try cranking the engine.
You can get a refurbished ECU from O'Reillys Auto Parts for 250.00 + a core charge.
Good luck.
EDIT-
Just noticed that you're from Sherwood. That's not very far from me. If you're still having starting issues let me know and I'll try and find a time to stop by and help.
-13G's, MBC @ 15psi
-ARP Head Studs, Ported Heads
-Wiseco Pistons & Crower Connecting Rods
-RPS Street Max Clutch & Pressure Plate
-ESP Downpipe, Gutted Cats, EGR Blockoffs
-3SX Polyurethane Motor Mounts
-MSD 8.5mm Spark Plug Wires
-Hotwired Supra fuel pump, Resistor Bypass
-Dejon Dual Intakes
-MAFT-Pro in Speed Density
jwetzler is offline   Reply With Quote
Old 02-07-2008, 02:54 AM   #15 (permalink)
BMFRU2's Avatar
Thank's for the offer. Will hit you up after I trace this .07 drain on batt. I think Batt core is bad, or Alt is bad. Getting new Batt within the week. At the same time will get new ECM from Auto Zone. No Offense to O'reilly's, but a refub doesn't inspire confidence.
If any one has any experience with PDA 3 xe for a download, I could use the help.
Old 02-07-2008, 06:25 AM   #16 (permalink)
91 Stealth TT
jwetzler's Avatar
Trader Rating: (6)
I've been running that refurbished one from Orielly's for over a year now with no issues.
You're going to get stuck with either a refurbished one or a used one no matter where you buy it from, autozone or oreilly's.
The only place to get a new one from is the dealership, and you're looking at 800.00+
I'm not familiar with PDA 3 xe, what exactly is that?
Old 03-02-2008, 01:27 AM   #17 (permalink)
BMFRU2's Avatar
PDA is a Data logger. All fuse look good, Want to get a starter relay and a MFI relay. Taxes here makes it cheaper to send away for parts. So I'm still in a holding pattern.
Old 05-04-2008, 01:49 AM   #18 (permalink)
BMFRU2's Avatar
Has anyone had a bad experience in buying an ECU from AZ, O'reilly, or Auto advance? Numbers match, but pictures doesn't. Don't want to be stuck with restock fee.
Also, installed MAFT NOT pro. Still think I need an ECU.
Old 05-06-2008, 07:47 PM   #19 (permalink)
500hp daily driver
Trader Rating: (15)
you should be fine buying from one of the parts stores.
Old 05-07-2008, 12:04 AM   #20 (permalink)
Drives a Twin Turbo Tank
XtremNiteCrawlr's Avatar
Drives: '95 VR4
Trader Rating: (6)
XtremNiteCrawlr is an unknown quantity at this point
chris bought 1 from oreillys and we had to swap it back in they come with a warranty and will swap it out for ya if theres a problem...
XtremNiteCrawlr is offline   Reply With Quote
