#11 (permalink) | |
#12 (permalink) |
Almost 18 y/o VR4
once you get a stock ecu back in there you will be able to read the check engine light and see whats wrong.
-Marshall
2nd Place "Best 1st gen" category '08 NG Car Show ![]() Check out My Pics and "The Story of My Car" UPDATED 6/22/08 with engine rebuild Engine rebuild: Done! 8/07 Paint: Done! 11/07 |
#14 (permalink) | |
91 Stealth TT
Also you can pull a spark plug wire and touch it to ground and see if you are getting any spark when you try cranking the engine. You can get a refurbished ECU from O'Reillys Auto Parts for 250.00 + a core charge. Good luck. EDIT- Just noticed that you're from Sherwood. That's not very far from me. If you're still having starting issues let me know and I'll try and find a time to stop by and help.
![]() Currently a member of the Spun Bearing Club -15G's, MBC @ 7psi -ARP Head Studs, Ported Heads -.80 Ross 8.5:1 Pistons & Crower Connecting Rods -RPS Street Max Clutch & Pressure Plate -ESP Downpipe, Gutted Cats, EGR Blockoffs -3SX Polyurethane Motor Mounts -Hotwired Supra fuel pump, Resistor Bypass -Fuel Labs AFPR @ 44psi -Dejon Dual Intakes -MAFT-Pro in Speed Density Last edited by jwetzler : 01-09-2008 at 11:51 AM. |
#15 (permalink) |
Thank's for the offer. Will hit you up after I trace this .07 drain on batt. I think Batt core is bad, or Alt is bad. Getting new Batt within the week. At the same time will get new ECM from Auto Zone. No Offense to O'reilly's, but a refub doesn't inspire confidence.
If any one has any experience with PDA 3 xe for a download, I could use the help. |
#16 (permalink) | |
91 Stealth TT
You're going to get stuck with either a refurbished one or a used one no matter where you buy it from, autozone or oreilly's. The only place to get a new one from is the dealership, and you're looking at 800.00+ I'm not familiar with PDA 3 xe, what exactly is that? |
#18 (permalink) | |
Also, installed MAFT NOT pro. Still think I need an ECU. |
