#13 (permalink) |
One Sinister Motha Sucka!
go to co3s.org
91 Vr4, TDO4L 13T's, oil cooler, new vss, rebuilt engine with 99 big bore lifters, Fel-pro head Bolts, IPS Ross (.030) Pistons and Rings, brand new forged mitsu oem crank, clevite bearings, all new gaskets and seals, new oem oil pump, new water pump, all new gears and synchros(1-5 and reverse) new oem motor mounts, 99 rear Garnish, Greddy Profec-B Spec II EBC, evo8 560cc injectors, Apexi SAFC-II, walbro 255 FP, 120k, hks SSQV, borla 3", downpipe, gt-pro FMIC, XTD stage 3 racing clutch, Brand new two tone custom interior, x2 Kicker Comp 12" subs, infinity Kappa 3 stage 6x9's more to come...and also 98 conversion have the parts just waiting to get the car back from the shop!!
#16 (permalink) |
i was wondering if colorado had their own 3s web site if so can you give me the url at pfluegerfishing@msn.com or just message me on the forum
#17 (permalink) | |
Senior Member
See you there. Dean
1994 Black 3000GT VR4 w/only 38,500 miles: IPS thermal coated headers, o2 housings, and EVO 3 16g turbos, Dynamic Racing Stage 3 heads, Fidenza cam gears, UDP, RPS flywheel, Weisco forged and coated pistons, Dejon tool intake pipes. Alamo intercoolers (bigger than HKS), DN hardpipe kit, DN y-pipe and downpipe, HKS SSBOV, Extrude-honed upper and lower plenum, 780 PTE injectors, MAFT Pro in speed density mode, HKS Hotwired fuel pump, Kenne bell boost-a-pump, AEM FPR w/gauge, Greddy turbo timer, HKS 3" Super Drager Exhaust w/5" single tip, Greddy Profec A boost controller, ARM1 air/fuel gauge, ACT 2600 clutch, Eibach 1" lowering springs, Brembo front calipers, Greddy peak hold white faced gauges including boost, water temp, oil pressure, (2)EGT's, and oil temp, PLX300 wide band, SMC Alcohol injection system. PST 2 piece Carbon fiber drive shaft.
#19 (permalink) |
Hey everyone. There is still time to sign up for this year's gathering.
RMS Home Page Hope to see you there.
'95 Black VR4
