Go Back   3000GT/Stealth International Message Center > Regional Discussions > International(NON USA) > Canada 3/S
Old 07-23-2009, 03:07 AM   #1 (permalink)
samwongbc is an unknown quantity at this point
Default Maintenance in Lower Mainland BC
Let's use this thread to talk about maintenance in Lower Mainland area.
I just installed new Eagle GT tires. They are pretty nice. My car drives straight as an arrow but it is time to get a 4 wheel alignment anyways since my last set of tires was wearing unevenly.
Where are some places that know to disconnect the tie rod before doing the alignment on our AWS cars?
From Chang:
West Coast Alignment & Frame Ltd
1801 Powell Street, Vancouver
From Gerard:
21st Century alignment
6928 Palm Ave, Burnaby
Any others?
1993 Stealth R/T Turbo: PST carbon fiber driveshaft, Kormex tranny, Hella fog lamps, K&N Aircharger, Eagle GT tires, Dave Best polished "Stealth" spark plug cover, 250,000km.
Pics
samwongbc is offline   Reply With Quote
Old 07-23-2009, 03:14 AM   #2 (permalink)
Default Re: Maintenance in Lower Mainland BC
I am having a hard time changing gears sometimes. My clutch pedal sometimes has to be all the way to the floor before I can change gears. Sometimes it'll grind. I think I need a new master cylinder. Anyone changed theirs lately? Did you have the same sympton?
Where's a good place to get one?
Part number: MB555423
In USD:
$111.20 at Norco,
$97.30 at Cherry Hill ($128.80 for the Stealth)
$127.95 at 3SX
$111.20 at Rockville
Old 07-23-2009, 03:22 AM   #3 (permalink)
The gasket in my Y-Pipe has been damaged for the past 2 years now. The Y-Pipe sometimes comes off after my mechanic doesn't tighten it properly and I accelerate hard. I think I should get a new Y-Pipe now.
Air Duct to Throttle Body
Part number: MD161557
In USD:
$99.82 at Norco
$99.82 at Rockville
$79.80 for Stealth $87.35 for the VR4 at Cherry Hill. EDIT: Prices changed. Now $91.20 for Stealth, $89.84 for VR4.
Old 07-23-2009, 12:01 PM   #4 (permalink)
Gerard's Avatar
Gerard is an unknown quantity at this point
21rst Century allignment is amazing, Ollie, he has the newest equipmient and is very methodical in his work... he just did 1 1/2 hours on my car for $ 100.00 4 wheel all camber etc etc... car is striaght ! I have 20 " rims and 275 Tires too...
604 433 4008
6928 plalm ave
Burnaby
3000GT 97 SL blacktop,18 inch staggered 350z rims , SS Brake Lines Drilled/slotted Rotors ,Tein Flex Coilovers,k&n cold air intake, full custom exhaust titanium exhaust tips black carbon fiber cans, translab shift kit + tranny cooler/ push button ignition, 7 inch EANON touchscreen/dvd with hd backup cam, custom exhaust /ground wire kit/ red engine dress up/ 10"sub and a whole lot more to come !
Gerard is offline   Reply With Quote
Old 07-24-2009, 02:03 AM   #5 (permalink)
Thanks Gerard. I'll check them out sometime. How did you hear about them?
Just about to place an order for my Y-Pipe and master cylinder at Cherry Hill. The Y-Pipe price went up a few bucks since yesterday. Weird.
Old 07-24-2009, 03:26 AM   #6 (permalink)
WTB passenger snake eye
JDM GTO's Avatar
Drives: 91 GTO TT
JDM GTO is an unknown quantity at this point
Any suggestions for a leaking rear differential? After a drive, it will leak about 10-15 drops of Redline gear oil. It doesn't leak if not driven.
I'm thinking the seals need to be replaced, or maybe the seam needs to be re-welded. Any reliable (hopefully well priced) places you recommend?
JDM GTO
JDM GTO is offline   Reply With Quote
Old 08-06-2009, 03:15 AM   #7 (permalink)
BC3S
rez604's Avatar
Drives: '90 GTO TT
rez604 is an unknown quantity at this point
if you dont have a perpendicular crack along the gasket, its a waste of money to buy a new one. get a tclamp from any hardware store (i got mine from princess auto) and torque it down. pressure tested to 20psi with no leak. just take your worm clamp in and get a tclamp with similar size.
bpu+deletes
dyno run vid
rez604 is offline   Reply With Quote
Old 08-07-2009, 06:47 PM   #8 (permalink)
chunsangp
chunsangp's Avatar
chunsangp is an unknown quantity at this point
From Chang:
From Gerard:
Any others?
Hi Sam,
Instead of West Coast Alignment, go here:
Advance Automotive
314-5930 No. 6 Road, Richmond, BC V6V 1Z1
Telephone : 604-278-1803
They are one of the most well known alignment shops in lower mainland.
I've done last 2 alignments at Advance and they were able to set everything up the way I wanted. Talk to Johnny and he will do alignments on lowered cars and big wheels like 24"s.
Another place would be Dale's Alignment in Langley.
http://www.revscene.net/forums/good-...alignment+shop
Dale's Alignment & Brake Ltd. (Langley B.C.) Established 1975.
hope this helps!
-92 Stealth TT (for sale!)
K&N FIPK, IPS polished Y-Pipe, MBC@14psi, Greddy Type-S BOV, custom single SS 3" cat-back w/true Apexi N1, IPS shorty downpipe, gutted precats, Test Pipe, EGR Blockoff Plates, JIC FLT-A2 Coilover, 3SX Adjustable Rear Control Arm, Enkei RPM-2 18x9 & 265/35 Pirelli P-Zero Nero, Autometer Boost/AF guage, HKS TT, ACT Street Clutch, 3SX SS Clutch Slave Line, 3SX Solid Rear Motor Mount, Hawk HPS Pads, Clear H4 headlamps, EK2MFG Polished "TWIN TURBO" Plug Cover, Pioneer DEH-P5500MP Headunit, , custom "shortened" shifter
-09 Camry SE V-6 - 4300k HID
-07 Mazda3 GT
chunsangp is offline   Reply With Quote
Old 08-11-2009, 01:03 AM   #9 (permalink)
Originally Posted by chunsangp View Post
Hi Sam,
Advance Automotive
Hi Chang. This was where I had my alignment done last time. Did they do your Stealth? Did they disconnect the tie rod?
Old 08-11-2009, 01:05 AM   #10 (permalink)
Glad I bought a new y-pipe. This is what happens when the gasket from an old y-pipe gets sucked into the throttle body. Interesting lime Stealth.
1992 Dodge Stealth RT TwinTurbo, AWD, 5spd,Mint Body, ZERO Rust!
Update:
My car will be towed to the shop this week. Can't get into gear at all now.
