Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Front Wheel Drive - Drivetrain > FWD - Automatic
Old 10-07-2009, 10:01 AM   #1 (permalink)
Kenny88880's Avatar
Drives: 1995 Mits 3000gt SL
Kenny88880 Negative 1
Default Yet another transmission problem
All of this started at the same time. I normall drive IN overdrive. All of a sudden overdrive light does not come on on the dash, switch on shifter DOES work. When it is IN overdrive the car only has first gear then goes into neutral when it is OUT of overdrive the car runs fine just feels as if first gear is drawn out too far. UNLESS I step on the gas all the way, then the car wont shift out of first. Basically the only way I can drive my car is very gingerly OUT of overdrive. When overdrive is ON, and I try to manually shift out of first it will not come out. When overdrive is off, and I manually try to shift, it wont come out either. Something is seriously wrong with my transmission and/or the components and this is about to be the last straw. Is it possible that a tranny of a different year is in my car and its just different enough to work for a while but not correctly because my tranny has be swapped multiple times by a Firestone. (My dad knows them there). Are there numbers on the tranny that could tell me if its correct or not.
Kenny88880 is offline   Reply With Quote
Old 10-07-2009, 10:18 AM   #2 (permalink)
never a dull moment
DCIV's Avatar
Drives: 93vr4 & 92vr4
Trader Rating: (13)
DCIV Level 1DCIV Level 1
Default Re: Yet another transmission problem
You know wayne has been rebuilding all of our trannys right now. I bet he could look at yours.
Coop
To many mods to list.
Old 10-07-2009, 10:48 AM   #3 (permalink)
Kenny88880's Avatar
I dont know wayne. Its just very inconvienent because I am in college. How do I get in touch with Wayne
Old 10-07-2009, 10:54 AM   #4 (permalink)
Kenny88880's Avatar
Is this possibly Limp Mode/Safe Mode?
Old 10-07-2009, 11:39 AM   #5 (permalink)
never a dull moment
DCIV's Avatar
Trader Rating: (13)
his name is jackhammer, look for his post in the TN or for sale sections and then PM him.
Coop
Old 10-07-2009, 02:44 PM   #6 (permalink)
Kenny88880's Avatar
Well my trans just died
