Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Front Wheel Drive - Drivetrain > FWD - Automatic
Old 04-28-2005, 02:51 PM   #1 (permalink)
This, too, shall pass.
JoshAnker's Avatar
Drives: 95 Stealth
Trader Rating: (28)
JoshAnker Level 3JoshAnker Level 3JoshAnker Level 3JoshAnker Level 3
Default We need a walkthrough for an ATX flush/filter change
Any volunteers? A written one would be a huge help, pictures would be even better
This is the BASIC MINIMUM for maintenance for our transmissions, and I was unable to even locate a walkthrough for it!
JoshAnker is offline   Reply With Quote
Old 04-28-2005, 07:47 PM   #2 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (174)
BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7
Default Re: We need a walkthrough for an ATX flush/filter change
http://www.plymouthlaser.com/skit.htm
Follow the first couple of steps to this.
1993 3000GT FWD ATX TT - daily<----------------------->1984 Nissan Maxima - project
Old 04-28-2005, 10:35 PM   #3 (permalink)
JoshAnker's Avatar
Drives: 95 Stealth
Trader Rating: (28)
Please let me know if these are the correct steps:
1. Remove drain plug, drain tranny.
2. Remove the 14(apply to us also?) pan bolts and drop the transmission pan.(How heavy is it? will it kill me if I'm under it, or is it light?)
3. Inspect for metal shavings, grit, etc, and then wipe clean.
4. Remove the transmission filter. (Is it also black and held on by 4 bolts for us?) Will a new filter replace the entire unit, or go inside the housing that was hold on by bolts? (i.e., is it a housing or the filter itself?)
I stopped at "Remove the 10mm bolts to drop the valve body down" since I'm assuming that's for the shift kit install, not a tranny flush. Would the next steps be:
5. Replace gasket, replace filter, re-bolt transmission pan?
Tyler, you're (Along with Brett) pretty much the authority amongst ATX 3/S owners. At least you guys are the active atx 3/s owners that come to mind I REALLY appreciate the help, since I need to do my flush, and I'm pretty sad when it comes to doing stuff like this. That said, I AM willing to get my hands dirty and learn, I just need to be 100% sure I'm NOT going to fuck up my car by doing something stupid
There's ATF-3 and ATF-4 in terms of fluid, right? Does it matter which one I use? I have a feeling any brand name ATF-3 will suffice. Also, if I check with the auto parts store and ask someone at the counter, can they get me the correct filter/gasket, or do you have a link/phone # of who i can call for a new set?
I appreciate the help, and I'll be sure and photo everything I do so that we WILL have out own picture walkthrough for future reference
Old 04-28-2005, 10:46 PM   #4 (permalink)
Your tech at Tech
Caffinated Soap's Avatar
Drives: '93 3kGT
Trader Rating: (11)
Caffinated Soap is an unknown quantity at this point
The pan is pretty light. You'll definately be able to handle it with one hand. Trust me, I weigh 135lbs. It's my race weight.
I'm pretty sure there's 14 bolts. I didn't count mine last time I did it but I remember there was quite a few. Some of them are a little hard to get to from underneath the car.
There should be three little magnets in the bottom of your tranny pan. These will undoubtedly have some metal shavings on them, so don't be concerned about them. Wipe the entire pan down (magnets and all) untill it's nice and squeaky clean.
The tranny filter on mine was an aluminum color, but I don't think that matters. A new filter is the entire aluminum housing you see in the picture. It's filled with a cloth-type filter and should have a gasket on the top of it. NAPA carried mine and had it in stock. Most places should carry them and at least be able to get you one within the week.
Don't drop the valve body. That's just making things harder on yourself.
Replace the filter. Replace the gasket, wire brush the old one off if necessary. Re-bolt the pan on.
I filled mine up with Castrol ATF+3, available at most auto parts stores. I picked mine up at Autozone. In most Chrysler transmissions ATF+4 has superceeded ATF+3 because it is a higher quality fluid. My tranny doesn't seem to mind the ATF+3 though.
Caffinated Soap is offline   Reply With Quote
Old 04-28-2005, 10:47 PM   #5 (permalink)
BigTyla's Avatar
All of those steps are correct. The oil pan is pretty light, but I am Big Tyler so don't take my word for it.
Any ATF-3 will do fine. Don't get anything else unless you want to grenade your tranny.
Also be sure to get a filter kit with a GOOD rubber gasket and not some crappy cork gasket. The filter will look just like the black thing in the picture.
Old 04-29-2005, 09:25 AM   #6 (permalink)
I've been here way too long
Trader Rating: (26)
Mitsugirl3kgt is an unknown quantity at this point
I just did my in-pan filter and fluid change and decided to go with AMSOIL Synthetic Supershift Racing Automatic Transmission Fluid instead of the normal ATF-3. It's expensive but you can order it from Amsoil directly or from John @ IPT.
.02
Mitsugirl3kgt is offline   Reply With Quote
Old 04-29-2005, 09:27 AM   #7 (permalink)
4u2nv's Avatar
Drives: FWDTT
4u2nv is an unknown quantity at this point
Arrow Re: We need a walkthrough for an ATX flush/filter change
Got to love that Amsoil. I use Amsoil 10w 30 for my oil.
1998 DOHC 3000GT - FWDTT - 309 FWHP @ 8 PSI
Modifications :
Performance ;
ATX -> VR-4 MTX Swap -> TT Conversion (9b's); Limited Slip Differential, RPS Street Max Clutch, RPS Lightened Flywheel, Short Shifter, MSD Spark Plug Wires and Spark Plugs, Air Intake, Unorthodox Underdrive Pulley, Stillen Downpipe, Rear Precat Eliminator, ATR Single Shot Exhaust, Fidanza Adjustable Cam Gears, Greddy Prfec-B Boost Controller, Greddy Type-S BOV, Nexus Gauges, Eibach Lowering Springs, Solid Motor Mounts, Dyna Batt, Kazera KZ-A Lightweight Rims, Fuzion ZRI Tires.
Appearance ;
Clear Corners
4u2nv is offline   Reply With Quote
Old 04-29-2005, 10:41 AM   #8 (permalink)
Trader Rating: (26)
Royal Purple 5w30 for winter and Castrol Syntec 20w50 for summer.
Old 04-29-2005, 11:32 AM   #9 (permalink)
Your tech at Tech
Drives: '93 3kGT
Trader Rating: (11)
.02
Have you noticed any difference in the tranny? Shift quality? I'd like to know if there's any noticable difference in the AMSOIL and my Castrol ATF+3.
Old 04-29-2005, 12:02 PM   #10 (permalink)
Trader Rating: (26)
I don't know yet I haven't driven it. The car is still at a shop 300 miles from where I live. I went up to get it last weekend but we ran into some issues and it wasn't ready to drive back. I got a call yesterday saying that everything is good to go, just need to find time to go get it. I'll let you know if there is any difference.
