Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Front Wheel Drive - Drivetrain > FWD - Automatic
Old 06-23-2006, 07:29 PM   #1 (permalink)
Daily Interlude is an unknown quantity at this point
Default torque converter/flexplate/flywheel disassembly???
I only need to replace the part w/ the teeth and the manual online ( http://www.ecanfix.com/users/manualc...ullchapter.pdf ) shows a break down with them apart (labeled 23-65 but page 75 in the PDF) and a pic I found on autozone shows the converter w/o it...
So how do I get them apart?
Mine (click for full size...check out the last pic, you think that's the reason the starter was just spinning and not engaging it?):
Daily Interlude is offline   Reply With Quote
