#1 (permalink) |
Well, My TCU was in limp mode, replaced the main electrolytic capacitors, but it damaged a SMD capacitor, its capacitor C30 that one side is missing on, Does anyone know its size and spec? I can't find it anywhere, its all I need to make mine repaired. Please someone has to know! Thanks!!
It is like a 2mm by 2mm cap that looks tan or light brown in color if anyone know values of capacitors by size/color.
'92 Dodge Stealth ES DOHC ATX
Snake Eyes, Topline Engineering Ground Kit, Intake Resonator Removed, Rebuilt ECU&TCU, VentusII HR Tires NGK Laser Platinum Spark Plugs '90 Dodge Daytona ES V6 (6G72) MTX A543 3.77FD, Optima RedTop, KYB's all around, 58mm TB, 2.5" CAI, 1" intake spacers, BPE underdrive pulley, Strut tower bar, solid motor mounts, Fidanza Aluminum Flywheel + more |
