Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Front Wheel Drive - Drivetrain > FWD - Automatic
Old 02-22-2009, 01:15 PM   #51 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1992 Stealth TT
Trader Rating: (59)
Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2
Default Re: Does your ATX suck...?
Originally Posted by 21bubba View Post
With the shfter in drive position and the switches controling the shift solenoids.
ok.
Whoever replaced their selector switch and noticed an improvement, take the thing apart and post pics on here. I want to see what "failed" inside the switch.
Did you use a tester and check the pinouts to verify there was actually a problem with the switch? I smell the fallacy of false cause around here...
Power:13Ts, 550s, AEM FPR, Emanage Blue, K&N, Downpipe, ATR Catback, DevilsOwn meth, UDP, SSQV, EVC5, Walbro, IK24s
Best 1/4 12.62 @ 111.9 2.0 60 FT Best 1/8th 8.00 @ 87.24 1.80 60FT
Suspension: Konig Villians, Pilot A/S, Tein S-Techs, Hawk HPS Pads, 2G brakes AWS Delete
Drivetrain: ACT HDMM, 300m O/S, PST 2 piece Al/Steel Driveshaft, F&R Poly Mounts, EK2 ExoCage
Etc: Leatherseats.com Charcoal/Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps, Scanmaster3, AEM UEGO, 3sx single pass 2" radiator
Samco rad hoses, Smokin'vr4 sub box with 10" MTX sub, Pioneer Amp, JVC KD-ADV49
Ball bearing STS
Forest Gump is online now   Reply With Quote
Old 02-22-2009, 02:13 PM   #52 (permalink)
Thread Hijacker
aliasisapac's Avatar
Drives: '98 3000GT SL
aliasisapac Level 1aliasisapac Level 1
ok...
with every automatic car i've driven, there has been a delay with the 1-2 gear change.
let me extrapulate...
on cold start-up, the transmission changes gears at a higher rpm, this event is significantly noticeable with the 1-2 gear change.
this event happens once maybe twice, depending on whether or not i have to come to a complete stop in a short distance/time.
don't tell me this isn't normal, when i've test driven several NEW cars that exhibit this characteristic.
Mods (in order of earliest to latest):
Ebay Intake - Random Technology Hi-Flo Main Cat - BigTyla's Ground Wire Kit - DDM Tuning 6K HID's - Complete De-Badging - Drag DR19's(affordable BBS's ) - Falken Ziex ZE-912's - Pre-Cat delete - Spoiler delete (incomplete) - Foglight delete - Nitrogen Tire Inflation - Eibach Lowering Springs - Niteshaded tails and corners
aliasisapac is offline   Reply With Quote
Old 02-22-2009, 02:16 PM   #53 (permalink)
Thread Hijacker
unable to comply.
missing required inquiry parameters.
i do not have the switch anymore... i replaced it almost 2 months ago...
Old 02-22-2009, 02:25 PM   #54 (permalink)
Drunk as a lord
Trader Rating: (59)
Originally Posted by aliasisapac View Post
ok...
many transmission control modules will hold 1st out longer when the car is cold to get the cats up to temp sooner. This has nothing to do with the torque converter "warming up"
Old 02-22-2009, 02:27 PM   #55 (permalink)
Thread Hijacker
ahh...
then i was misinformed.
Old 02-22-2009, 02:30 PM   #56 (permalink)
Drives: 93Es, 93rt
21bubba is an unknown quantity at this point
ok...
Reread my post #34, youare right but for the wrong reason.
21bubba is offline   Reply With Quote
Old 02-22-2009, 02:35 PM   #57 (permalink)
Give me Truth or Glory...
AudibleSilence's Avatar
Drives: without worries now
Trader Rating: (49)
AudibleSilence Level 2AudibleSilence Level 2AudibleSilence Level 2AudibleSilence Level 2AudibleSilence Level 2
The only thing manual on the 3s auto is the Reverse lever afaik. You can control it completely electronically, save for reverse. You need the shifter for the arm on the reverse lever. I know this because I am debating putting the manumatic in my 97.
I went over this with Bret.. Clutch lock up is controlled by a switch, the gears are controlled by button selection. All forward gears work this way, the only thing mechanical is reverse
Cars Owned:
1992 Dodge Stealth RT (sold)
1992 Mitsubishi 3000GT VR4 #1 (parted)
1992 Mitsubishi 3000GT VR4 #2 (sold)
1993 Mitsubishi 3000GT VR4 #1 (KIA)
1993 Mitsubishi 3000GT VR4 #2 (sold)
1994 Mitsubishi 3000GT VR4 (sold)
1994 Mitsubishi 3000GT Base - awd/atx (sold)
1997 Mitsubishi 3000gt VR4 (sold)
AudibleSilence is online now   Reply With Quote
Old 02-22-2009, 02:37 PM   #58 (permalink)
Thread Hijacker
but you made a funny here:
I would like to help you but you must type in some form of english.
Old 02-22-2009, 02:43 PM   #59 (permalink)
Drives: 93Es, 93rt
We are agreeing just saying it differently.
Old 02-22-2009, 02:44 PM   #60 (permalink)
Drives: 93Es, 93rt
I'm a funny guy
