05-14-2009, 10:29 AM
#4 (permalink)
AWD rules
Drives: 94 black SLTT & VR4
Re: car revs up and down when already engaged in overdrive...
Originally Posted by 21bubba
There's a very good chance that the two problems are connected.Read the thread "Does your atx suck". You also may need a end clutch.
^ Maybe right. From the ATX service manual, one of the causes that can prevent the car from shifting into 4th is a malfunction park/neutral switch, or damaged or disconnected wiring to it.
Black 94 SL Twin Turbo Automatic - 63K miles, < 1K on engine
purchased 3/2001, TT converted 6/2003
8.5:1 Arias Pistons, Pauter Rods, DR Stage 3 heads, 3sx td05 kit, EVOIII 16G's (currently set at 17 psi), PTC high-stall torque converter, shift kit, LSD, FMIC, 550cc injectors, walbro 255lph, 3SX single pass radiator, and supporting mods.
Black 94 VR-4 (The black wasp) - purchased 8/10/2009, 80K miles, R.I.P. 2/19/10
Air Intake, Blitz SBC-iD @ 14 psi, 50 lbs of wasp nests removed
2004 Jeep Grand Cherokee Special Edition - Daily Driver
