#1 (permalink) |
SOHC Power!!!
I just finished my auto tranny fluid cooler install and I took some pics. I had trouble finding info on the install, so I hope this helps someone.
1. Follow the instructions included with your cooler to it set up. 2. Locate the stock cooler feed line... ...and remove it. Keep the stock line, you may need it. 3. Connect the supplied line to the cooler. The line include with my cooler wasn't long enough, so I also used the stock line. 4. Run the lines around the a/c condensor... ...and fit the cooler into the bumper. This was the hardest part of the install, because the cooler was bigger than the bumper opening. 5. Connect one feed line on the cooler to the transmission... and the other feed line on the cooler to the stock cooler. 6. Follow the coolers instructions to secure the cooler. Make sure all of your hose clamps are tight. Add 1/2 qt. of tranny fluid... ...and you're done... ![]() ... ![]()
'93 Green 3000GT Fidanza 2.1 cltuch / Fidanza flywheel / 3SX ss clutch line / 3SX crank pulley / Lethal_VR4 manual steering rack / TT radiator / BigTyla ground wires / ebay intake / '99 lifters / TT fuel pump / Maximal solid motor mounts / 3SX long headers / TT race pipe / TT cat-back / KSport coilovers / Maximal rear toe & camber arms / UP rear strut bar / Seattle short shifter / TurboBob 8,800 rpm ECU ![]() Want to buy 3000GT or RT rolling chasis near KC. PM me! ![]() |
#3 (permalink) | |
want to tt
![]() Anyone in the Nashville area that can help me diagnose my car problems, let me know. Thanks |
#4 (permalink) |
This, too, shall pass.
nice write up
![]() Interested in the famous "Bandit" movies featuring a Stealth RT/TT? I have all 4 on DVD! PM me for info! Google logo thread | 3Si Area of Expertise thread | 3S Audio FAQ 3si faces page | 99 Front-End conversion page | 3S Quicklist walkthrough for removing your spoiler | walkthrough for changing your ATX fluid |
#5 (permalink) | |
SOHC Power!!!
#6 (permalink) |
i made mine for free, ran it after the stock cooler, used a similar cooler from a suburban, (prolly not stock) its not painted, it looks good mountd behind the big hole where the fog lights are missing, kinda looks like a side mount, and the trans likes it!
84 volvo 242 turbo
93 base masive oil leak mod |
#7 (permalink) |
Engineering Student
Do we still need to run the line through the radiator? If so, why? Wouldn't this warm up the cooled fluid? I have seen people on here with tranny coolers and the line still goes through the bottom right part of the radiator.
![]() NG06 - DOHC NA - ATX --- 16.6 --- 85 MPH NG07 - DOHC NA - MTX --- 15.7 --- 89 MPH 7.78 sec 0-60 3,044 lbs w/out driver1992 3000GT 1991 Stealth |
#8 (permalink) | |
SOHC Power!!!
#9 (permalink) | |
Some Random Guy
Check Mark7's post (#18) Any interest in an external cooler/filter/gauge kit? Also, great work with the write-up. I was considering doing one but got lazy. I also think that you are using a Hayden cooler and not a Tru-Cool one which is what IPT sells.
![]() Last edited by StealthSOHCer : 06-30-2006 at 07:55 AM. Reason: More Info |
