Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Front Wheel Drive - Drivetrain > FWD - Automatic
Old 07-01-2008, 01:36 PM   #1 (permalink)
3KGTVT's Avatar
Drives: 1995 3000GT SL
3KGTVT is an unknown quantity at this point
Angry ATX Problem(s) HELP!
I bought my car at 91k miles. When I test drove it I noticed it had trans issues right from the get go. When I put it in Drive and hit the gas, the car would move about half a foot and kind of "pause" (front end of the car dipped down) and then would take off fine.
At 101k miles, the trans died completely. I had it rebuilt for $2400. It now has 104k, and the problem is coming back. Another problem is when it downshifts at around 20mph, into first, the front end of the car dips down and it almost feels like the trans jams for a second. The shop that rebuilt it gave me a 1-year warranty. Does anyone know what the problem could be?
3KGTVT is offline   Reply With Quote
Old 07-01-2008, 01:39 PM   #2 (permalink)
Drives: 3000GT
hawk362 Level 7hawk362 Level 7hawk362 Level 7hawk362 Level 7hawk362 Level 7hawk362 Level 7hawk362 Level 7
Default Re: ATX Problem(s) HELP!
Take the car back to the shop tell them you spent over 2k on the car and your having the same problem as when you brought the car to them, have them check it out and since they warrantied the tranny they have to cover it.
ATX 95 Base 3000GT
High stall torque converter, tranny cooler, Off brand intake, 3sx downpipe, test pipe, custom exhaust, 3sx underdrive pulley, NGK PLUGS, lamborghini doors, 18 inch black rims, limo tints, GTR HIDS, Alpine in dash dvd screen
ZEX 100 WET NITROUS SHOT
"WOW YOUR CAR IS SO SPARKLY, WHITE, AND DAMN SEXY YOU MIND IF I SNORT IT?"
hawk362 is offline   Reply With Quote
Old 07-03-2008, 11:27 PM   #3 (permalink)
RL7
RL7 Level 4RL7 Level 4RL7 Level 4RL7 Level 4RL7 Level 4
There's probably a problem with the valve body and/or solenoids. Ask the shop if they looked over or fixed the valve body. There may be valves sticking or something like that. This caused your tranny to self destruct once, so if left alone, it will probably happen again.
You may want to check your fluid level first. If it's low, refill and look for leaks.
RL7 is offline   Reply With Quote
Old 07-07-2008, 08:11 PM   #4 (permalink)
Q-Bert
IronFish's Avatar
Drives: 1991 3000GT SL
IronFish Level 7IronFish Level 7IronFish Level 7IronFish Level 7IronFish Level 7IronFish Level 7IronFish Level 7IronFish Level 7
I agree 100%. Check the fluid level and for leaks. It sounds valve body related. Unless you specify, most shops that rebuild these transmissions do not mess with the valvebody. It sounds like they should have checked this in the first place. Hopefully the warranty works out for you.
-Matt
1991 3000GT SL
ENGINE: 3.1L (bored .030), wiseco forged pistons, rebuilt heads with 5 angle valve job and '99 lifters, fidanza cam gears, webcams street-grind cams, Precision Turbo 525cc injectors, ported upper and lower intake plenum, UDP, 3KGT full length headers, 3KGT downpipe, test pipe, flowmaster 42 series, KN air filter with intake pipe, Maximal solid motor mounts, SAFC II, RIPP SDS (uninstalled)
SUSPENSION: 3sx front and rear strut bars, Addco front and rear sway bars, Tein Coilover system
BRAKES: Stillen brake pads, Stillen cross drilled rotors, 3sx SS brake lines,
TRANNY: Complete Rebuild by IPT, ElectroMatic Shift Box, 3200 stall Torque Converter, IPT valve body w/shift kit, alto end clutch, Kormex LSD
EXTERIOR: 17x8 Chrome Eagle 077s wrapped in Toyo Proxes, clear corner front turn signals
IronFish is offline   Reply With Quote
Old 07-07-2008, 08:16 PM   #5 (permalink)
3KGTVT's Avatar
Mitsubishi Re: ATX Problem(s) HELP!
Ill give them a call. Another thing is, the trans shifts fine with overdrive off....Why doesnt it with it on?
Old 07-07-2008, 08:18 PM   #6 (permalink)
Q-Bert
IronFish's Avatar
End clutch is probably toast. Overdrive is 4th gear which is the end clutch. When you turn it off, the transmission wont engage in this gear. When it is on, the car may try to shift but will shift to "nothingness" as the gear is not working.
For whatever reason, the end clutch likes to fail. Its most likely a result of improper cooling. I would look into an upgraded end clutch. Alto made one (I think they still do) and I would google that (Alto end clutch). I have had mine for over 5 years and it has not gone out yet.
Old 07-07-2008, 08:20 PM   #7 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (13)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
tranny cooler FTW.
inperfectdarkness is offline   Reply With Quote
Old 07-08-2008, 12:22 AM   #8 (permalink)
RL7
You can get an end clutch here:
IPT Performance Transmissions Torque Converters and Transmission Parts for Ford, GM, Chrysler, and Import vehicles
Replacing it is a pretty easy job. Messing with the valve body is a bit tougher.
