Old 05-04-2008, 07:55 PM   #1 (permalink)
on weekdays.
chrisincobb's Avatar
Drives: SHORT DISTANCES
chrisincobb Level 3chrisincobb Level 3chrisincobb Level 3chrisincobb Level 3
Default what needs to be removed to access the rear speakers?
It looks like everything behind the front seats has to come out. please tell me thats not true. if i have to, i will break out the dremel and cut the old ones out! i mean there the covers are, and snap, off they come. then it looks like the speaker is behind something thats behind something else and so on and so on. any ideas or shortcuts would be nice. thanks!!
chrisincobb is offline   Reply With Quote
Old 05-04-2008, 08:07 PM   #2 (permalink)
BLah
kjnphx's Avatar
Drives: 95 3000GT
kjnphx Level 1kjnphx Level 1
Default Re: what needs to be removed to access the rear speakers?
Stealth 316 - Quarter Trim Replacement
Its easy shouldnt take u too long......
-- Edit --
its not necessary to remove driver and passenger seatbelts. You can just let the panels hang there
kjnphx is offline   Reply With Quote
Old 05-05-2008, 08:00 AM   #3 (permalink)
Moderator
Lord Warlock's Avatar
Drives: 2004 SVT Cobra,91TT
Trader Rating: (9)
Lord Warlock level 6Lord Warlock level 6Lord Warlock level 6Lord Warlock level 6Lord Warlock level 6Lord Warlock level 6
the rear seat belt shoulder harnesses, and the side panels, you'll also want to pull the rear seats out. You can get by with just pulling the panels up and out of the way, but you risk breaking them if bent too far.
Lord Warlock is online now   Reply With Quote
Old 05-05-2008, 08:06 AM   #4 (permalink)
My Stealth is Confused...
Stealth_E's Avatar
Drives: w/o a front plate OH
Stealth_E Level 1Stealth_E Level 1
Step 1: Take off pants
Step 2: ????
Step 3: Profit
Stealth_E is offline   Reply With Quote
Old 05-05-2008, 12:01 PM   #5 (permalink)
3KGTVT's Avatar
Drives: 1995 3000GT SL
3KGTVT is an unknown quantity at this point
Yeah all that has to come out. Its not a hard job though. I put some Pioneer 6x9s back there in about an hour, its well worth it.
3KGTVT is offline   Reply With Quote
Old 05-05-2008, 12:16 PM   #6 (permalink)
Mr. Cheese
92RT-TT's Avatar
Drives: 92 RT/TT & 92 RT/TT
Trader Rating: (15)
92RT-TT level 692RT-TT level 692RT-TT level 692RT-TT level 692RT-TT level 692RT-TT level 6
I gotta do this too. I've got some new infinity 6x9's I wanna put in the back. Plus having this off would be a good time to clean the seatbelts so they retract a little better
1992 Dodge Stealth RT-Twin Turbo
64,000 miles, Stored Winters, AEM Tru-Boost, Greddy Type S BOV, DNP Hardpipes, Palm MMCD, Tein S-Tech Springs, Brembo Rotors, MSD Wires, K&N FIPK, EGR Delete, Vacuum Reduction, Cianci 3 Gauge A-Pillar, 5zigen FN01R-C 18x9.5's wrapped in BFG KDW 265-35-18's. 13% Tint, 12 Disc CD changer, 3 1/2 inch Custom Exhaust.
DD-Pearl White 92 Stealth TT-85,000 on it, BPU 270 awhp, 307 awtq on 8-23-08
92RT-TT is offline   Reply With Quote
Old 05-05-2008, 06:50 PM   #7 (permalink)
on weekdays.
sounds like STEALTH E has the best plan so far............
Old 05-07-2008, 08:01 PM   #8 (permalink)
porbund's Avatar
Drives: 1993 Sealth Base
porbund is an unknown quantity at this point
yes, Stealth E's plan intrigues me as well... I'm already halfway to the profit
1993 Dodge Stealth Base
1995 Plymouth Voyager-DD, mitsu 3.0L SOHC
"someone must've pulled the f*** switch"
Plymouth Voyagers improve with age, like a fine wine:
http://www.3si.org/forum/f36/222hp-d...ml#post4677717
porbund is offline   Reply With Quote
Old 06-28-2008, 03:39 PM   #9 (permalink)
on weekdays.
Unhappy Re: what needs to be removed to access the rear speakers?
HA! took me all damn day not to mention blood, sweat, and tears. and guess what? THEY SOUND EXACTLY THE SAME AS BEFORE!!!!! even though the original ones had no surround left and the paper was nearly turned to dust, the BRAND NEW ones i just spent all f*cking day installing sound no better. they still cut out when they want, and when they do play, it's awful. and yes the polarity was kept intact. must be the head unit? i bet i replace that and get the same difference somehow...... YOU HAVE NO IDEA HOW MUCH I WANT TO BURN IT!!!!!!!!! :HA!
Sign by Danasoft - For Backgrounds and Layouts
Old 06-30-2008, 04:44 PM   #10 (permalink)
BlueMonkey is an unknown quantity at this point
its thr stock amp you must have..... Just run your own wire from your head unit to your speakers and that should solve your problem..
BlueMonkey is offline   Reply With Quote
