voltage drop... help - 3000GT/Stealth International Message Center
Old 10-09-2002, 08:53 PM   #1 (permalink)
Now with 100% more meth
sublime_whatigo's Avatar
Drives: reliable car (nissan
sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3
Feedback Score: 27 reviews
Default voltage drop... help
stock sound except for deck. i have voltage drop so bad the lights dim and the deck shuts off and goes back on. With the car running with the car off, same thing but it takes more accesories with the car on. I put in a new battery and it didnt help.
Only thing i can think is i got a loose connection somewhere, but where?
92 3000GT VR4
Matt
sublime_whatigo is offline   Reply With Quote
Old 10-09-2002, 08:58 PM   #2 (permalink)
Teazersnow's Avatar
Teazersnow is an unknown quantity at this point
Feedback Score: 0 reviews
Default
follow a wiring diagram and see where the power is comin from then check if there are any shorts to ground.
Teazersnow is offline   Reply With Quote
Old 10-09-2002, 09:04 PM   #3 (permalink)
Default
i got no sparks when i pulled the old battery off and put a new one in. so i dont think its a short to ground. maybe a loose ground. i was hoping someone had this problem and could pinpoint it so i dont hafta go through the whole car.
Old 10-09-2002, 09:07 PM   #4 (permalink)
Teazersnow's Avatar
Default
how many watts is the deck?
i had an alpine 60x4 and it did that too i gave it its own power wire. or replace the old speakers becuase that might just be too much power for them so the deck is saving them.
Old 10-09-2002, 09:19 PM   #5 (permalink)
Default
its a really nice eclipse deck, but it only draws 2 amps supposedly. And could you explain that second part about replacing my speakers, i dont get it.
Old 10-09-2002, 10:27 PM   #6 (permalink)
It's just a game Focker!
Stealth1109's Avatar
Stealth1109 is an unknown quantity at this point
Default
This is not true. I had a similar deck shutting off problem and have confirmed from multiple car audio sources that the deck will NOT shut down if the speakers are overwhelmed, merely stop playing.
Stealth1109 is offline   Reply With Quote
Old 10-09-2002, 10:44 PM   #7 (permalink)
acrazor's Avatar
acrazor is an unknown quantity at this point
Default
Does your car have trouble starting? If it does, then you have a faulty ground. I tried starting my car with my deck in with no ground and it struggled to start.
My friend had bad problems with his lights dimming right before his alternator/battery went. You might want to check the output at the alternator with a voltmeter and see what its getting. I'm not a pro but this is what I remember from what I've done so I hope it helps.
acrazor is offline   Reply With Quote
Old 10-10-2002, 11:11 AM   #8 (permalink)
973000GTSL's Avatar
Drives: 97 3000GT VR4 Black
973000GTSL is an unknown quantity at this point
Feedback Score: 4 reviews
Default
You alternator could be going
1997 3000GT SL Black (sold)
1997 3000GT VR4 Black
13.48@101 stock
RoJa R2-5 18X9 w/Dunlop Direzza Sport Z1 Star Spec
KN FIPK
Stillen Rotors
IPS quad tip catback
IPS 3" DP
973000GTSL is offline   Reply With Quote
Old 10-10-2002, 11:15 PM   #9 (permalink)
Default
if anyone cares i fixed it. I ran a new lead to it straight from the battery. Apparently it normally comes out of the 3rd fuse box, basicallly a whole bunch of loads and 30ft of wire thats to small. Unless theres a loose connection in there somwhere.
Old 10-11-2002, 01:50 PM   #10 (permalink)
acrazor's Avatar
Default
My lights still dim a little bit when my subs pull harder. I'm guessing its from voltage drop. Could you explain what you did a little more in detail?
