Old 11-18-2009, 07:38 PM   #1 (permalink)
Iversonpr is an unknown quantity at this point
Question Sub Help
I'm still not sure if getting 2 10 kicker or one single 12 kicker
For the 2 10 kicker I would get the sub enclousure that fit perfectly behind the seats ( The total air space is aprox. 1.1, with no dividers)
But If I get the 12 sub I would get the corner sub box... (.95 cu ft)
Please anwser me fast I don't want the enclousure to be sold ...
I'm open to listen to opinions.. thankkks and excuse my english
Iversonpr is offline   Reply With Quote
Old 11-24-2009, 08:56 PM   #2 (permalink)
jug6ernaut's Avatar
Drives: 96 Base
jug6ernaut is an unknown quantity at this point
Default Re: Sub Help
hmm, while i have never heard subs in the box that fits behind the seat i and fairly sure that a single 12 in the corner would sound better then the 2 10 setup stated. U can get alot out of a single 12 in the corner location. but remember to sound proof the trunk...nothing (imo) sounds worse then a rattling trunk...
Pics of my new JL 13Tw5 setup
jug6ernaut is offline   Reply With Quote
Old 12-01-2009, 07:54 PM   #3 (permalink)
Stealth Like A Ninja
Darksurfr's Avatar
Drives: '91 Stealth TT
Trader Rating: (14)
Darksurfr is an unknown quantity at this point
Remember if you have no divider to use a series setup for the subs so you dont get mixed sound waves. 1 10" is more then enough but I think you need at least .7 for each sub. I guess they all vary. I built my own rear box to meet the demand for space for my 2 10" and walled them off in the center.
ECG '05- '09 / Attended NEG '05 - '08 / Attended
Darksurfr is offline   Reply With Quote
Old 12-10-2009, 10:33 PM   #4 (permalink)
I decided to buy the corner sub.. the box have .95 cubic feet and the suggested cubic feet for the 12 kicker is Sealed box volume: 1.0-4.6 cu. ft... is .95 enough for the sub ?
Old 12-10-2009, 10:53 PM   #5 (permalink)
Makin' moves like U-haul.
Firestorm95RT's Avatar
Drives: 95 Stealths & Vr-4
Trader Rating: (10)
Firestorm95RT Level 1Firestorm95RT Level 1Firestorm95RT Level 1
Buy a JL and be done with it.
Kicker is gay.
Rearview mirror. Jumbo Dice.
Boost hit hard like Kimbo Slice.
Firestorm95RT is offline   Reply With Quote
Old 12-11-2009, 12:54 AM   #6 (permalink)
1992 Stealth R/T
jbavousett's Avatar
Drives: N/A Beauty Queen
jbavousett is an unknown quantity at this point
^ What he said.
jbavousett is offline   Reply With Quote
Old 12-11-2009, 10:48 AM   #7 (permalink)
thanks for the suggestion.. but what about my box problem ?
Old 12-11-2009, 12:13 PM   #8 (permalink)
1992 Stealth R/T
jbavousett's Avatar
.05 cubic feet won't really be an issue...but you'll be looking at less internal volume than that. The sub basket and part of the cone will take up a chunk of the internal volume as well. If you have room to reverse mount the sub, that would probably be your best option.
Old 12-12-2009, 07:52 PM   #9 (permalink)
kmslayer's Avatar
Drives: 97 VR4
kmslayer is an unknown quantity at this point
I got a 13tw5 good stuff had it for a while, waited for them to come out with the sub, once the shop close by me got them in picked it up that day
powered with a JL 500/1 ( used with my old 12w3 , when I had a car with a trunk :P )
kmslayer is offline   Reply With Quote
Old 12-12-2009, 08:47 PM   #10 (permalink)
2fnloud's Avatar
Drives: 94 Stealth R/T TT
2fnloud is an unknown quantity at this point
WTH are you taking about? The way that you worded that it sounds like you are talking about series and parallel wiring the subs. The only thing that matters it to make sure that both speakers are running mono when there is no divider. It could even be two amps.
As long as:
They are the same amp
Dialed in to output the same wattage
Both amps are receiving the same mono signal
Wiring the subs in series and parallel only effect the ohm load of the amp, not whether or not the sub box has a divider.
IF I miss-understood what you meant I apologize in advance. But if you where implying that enclosures with or without dividers dictates the series / parallel wiring required for the sub then, I must raise the mast.
2fnloud is offline   Reply With Quote
