Old 05-17-2008, 02:24 PM   #1 (permalink)
Kowboy's Avatar
Drives: blue 1992 3000gt vr4
Kowboy is an unknown quantity at this point
Default Stock Security System Problems... help needed
I accedently set off the stock alarm system on my 92 vr-4 and can't start my engine over. Is there a way i could bypass the system or disconnect it to allow my engine to turn over. When i put the key in the ignition and turn it on the dash lights on ac pictogram light up and the fan kicks on, so i don't think it is an ignition problem by itself. If i'm posting in the wrong forum please direct me to someone who can help me out.
Kowboy is offline   Reply With Quote
Old 05-17-2008, 02:52 PM   #2 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
Trader Rating: (12)
RealMcCoy Level 7RealMcCoy Level 7RealMcCoy Level 7RealMcCoy Level 7RealMcCoy Level 7RealMcCoy Level 7RealMcCoy Level 7RealMcCoy Level 7RealMcCoy Level 7RealMcCoy Level 7RealMcCoy Level 7
Default Re: Stock Security System Problems... help needed
The stock alarm system is deactivated by unlocking one of the doors, or turning the ignition to on or acc. If that isn't working, there is something wrong, or it's not an alarm issue.
Because One broken Stealth just wasn't enough... I made twins..
RealMcCoy is offline   Reply With Quote
Old 05-19-2008, 11:54 PM   #3 (permalink)
Kowboy's Avatar
well I tried to do the turning the different key locks and turning the ignition. The problem is when the car was running the only door that would disarm the alarm was the passenger side door. I opened the driver's side door one day when it was locked and now it won't start. It may be an other problem, but I just don't know where to start to look.
Old 05-21-2008, 09:05 AM   #4 (permalink)
myfirststealth is an unknown quantity at this point
Use the key to unlock the door and try then
myfirststealth is offline   Reply With Quote
Old 05-21-2008, 09:08 AM   #5 (permalink)
silvert777's Avatar
Drives: 06 WRX, 91 StealthTT
silvert777 is an unknown quantity at this point
On my 91 even when the alarm is going off you can start the car, so I do not think the alarm is the problem.
Daryl
silvert777 is offline   Reply With Quote
