Old 09-04-2008, 03:41 PM   #1 (permalink)
stupidvr4's Avatar
Drives: 92 vr4
stupidvr4 is an unknown quantity at this point
Default Stock HU problem
OK so i was with some friends in my car and i put a song on from my ipod and about 5 seconds into the song, the radio shuts off. It still has power going to it though, the lights for it still come on and it displays time (the wrong time). But none of the buttons work except for the display button. If i hold it down, the time starts blinking a if you were going to set it. I put a 5amp fuse in it, but i dont know if thats the right one. And the radio doesnt say CODE on the front so the dealer cant really help me out right now. Anybody have any ideas?
stupidvr4 is offline   Reply With Quote
Old 09-04-2008, 07:45 PM   #2 (permalink)
stupidvr4's Avatar
Drives: 92 vr4
Default Re: Stock HU problem
somebody knows how to fix this
Old 09-04-2008, 07:47 PM   #3 (permalink)
jlgn_2000 is an unknown quantity at this point
Yes...get a new aftermarket stereo!
jlgn_2000 is offline   Reply With Quote
Old 09-04-2008, 08:38 PM   #4 (permalink)
wi3000gt's Avatar
Drives: 94 VR-4 Daily Driver
wi3000gt is an unknown quantity at this point
Are you sure you have all the power?
Don't know about every 3s radio and year but.....
- You should have a wire that has power all the time.
- You should have a wire that is only on when your ignition is on.
- You should have a wire that controls your illumination (based on the dimmer for your dash lighting).
Car Audio Wire Diagram Codes Mitsubishi - Factory Car Stereo Repair - Bose Stereo, Speaker / Amplifier Repair
Check out 3saudiofaq.com or stealth316.com for more information.
wi3000gt is offline   Reply With Quote
Old 09-04-2008, 08:44 PM   #5 (permalink)
wi3000gt's Avatar
One other thought. Do you have a steering wheel radio control? If so press the AM/FM button on it. It should turn on HU. If that works you have a problem with the knob and/or buttons on the front of the radio.
Old 09-04-2008, 10:25 PM   #6 (permalink)
stupidvr4's Avatar
Drives: 92 vr4
Yea i have the steering wheel buttons but thay arent doing anything either. I'll check out the wiring diagram
Old 09-09-2008, 10:15 AM   #7 (permalink)
Broken Down Again...
2ndgen2ndmitsu's Avatar
Drives: 1994 3000gt sl
2ndgen2ndmitsu is an unknown quantity at this point
When you first start your car does the radio show the time? If yes, what happens to the antenna when you use the thumb controls on the wheel, i.e. does it go up or not? If it goes up, I would start with the fuses under dash to make sure that they are all good. I have a 94 SL, and mine says to have a 10 amp fuse in it. I would start there. Let me know what happens, I will be working on my stock radio tomorrow and may be able to give more info then.
2ndgen2ndmitsu is offline   Reply With Quote
Old 09-10-2008, 11:09 AM   #8 (permalink)
'96 VR4
tachyon_ftl's Avatar
Drives: It's spos'd to move?
Trader Rating: (12)
tachyon_ftl Level 5tachyon_ftl Level 5tachyon_ftl Level 5tachyon_ftl Level 5tachyon_ftl Level 5tachyon_ftl Level 5
Check (that is, reseat) the connectors on the ribbon cables from the front faceplate of the radio to the chassis. You'll have to take the radio apart to check, but it's pretty easy to do that as I recall. Mine radio did something like what you're describing a couple of years ago, and that was all it turned out to be. Good luck!
GHOST - "Because it's white and it tends to vanish"
K&N FIPK, DSM Sidemounts, Hotwired Walbro, EK2 Fuel Loop & AEM AFPR, "The Only Known Dr. Stupid 3in SS DP in Captivity!",
Random Tech 3in Cat, Borla Catback, Greddy TT and EBC, Greddy Boost, Oil Prs and Fuel Prs in Cianci 3 Up Pillar Pod, Tein S-Techs,
Bilstein Struts, Maximal Control Arms, Carbotech Rotors/Pads and StopTech SS Brake Lines. In work- 450CC DSM Injectors and SAFC-2
tachyon_ftl is offline   Reply With Quote
Old 09-10-2008, 12:40 PM   #9 (permalink)
stupidvr4's Avatar
Drives: 92 vr4
I'll try those things out, thanks
