Replacing Factory Door Speakers - Page 5 - 3000GT/Stealth International Message Center
View Poll Results: Help Me Choose a Factory Door Speaker Replacement
Infinity Reference 6032cf (or 6032si) 13 72.22%
Polk Audio DB651 (or DB651s) 5 27.78%
Voters: 18. You may not vote on this poll
Old 11-19-2012, 12:50 AM   #41 (permalink)
CHRIS75's Avatar
Drives: 93 3000GT VR-QUATTRO
CHRIS75 is an unknown quantity at this point
Feedback Score: 24 reviews
Default Re: Replacing Factory Door Speakers
These are the four white plastic bases i am taking about :
They are flat on the front but not in the back.
Originally Posted by blizzy View Post
he was probably used to driving his civic and he punched 2nd hahahahaha
F1 ... Where Nascar & Indi Drivers Dream To Compete
Welcome Back Michael.
CHRIS75 is offline   Reply With Quote
Old 11-19-2012, 11:26 AM   #42 (permalink)
jordache16's Avatar
Drives: '94 Black VR4
jordache16 is an unknown quantity at this point
Feedback Score: 0 reviews
Originally Posted by CHRIS75 View Post
Hey yesterday i was working on this again.
So you kept the four white plastic bases that are on the door ( where the white bracket screw on ) ? if you did this the white bracket is now even deeper on cos the four white plastic bases have a longer butt on the back of them, then making them for sure unable to fit cos the window will hit it on it's way down, believe me i tried this yesterday.
Yeah, I kept the four white plastic bases on the door but I never tried rolling the window down. However, I do remember thinking that the door speakers may sound better if it were mounted flush with the door instead of floating in mid air, so I was considering either removing the plastic bases or cutting off the backs. I stopped short of doing any of this though b/c I was a little disappointed with the sound of the Kappas compared to my factory speakers. My factory front speakers don't sound the greatest but they aren't blown so I decided to just leave them in until I decide to add an external amp.
Can you tell how much room you are going to need to clear the window? I am concerned that cutting off the backs of the plastic bases may not be enough. If the window just barely hits the speaker then we should be OK. However, at this point it may be easier to make a custom bracket out of a piece of plastic as others have done.
jordache16 is online now   Reply With Quote
Old 11-19-2012, 01:59 PM   #43 (permalink)
Preserve a 3S
Dave57's Avatar
Drives: '95 RT/TT
Dave57 Level 1Dave57 Level 1
Feedback Score: 38 reviews
How deep are the speakers that hit the window?
I have to wonder if the window to speaker door clearance changed?
I know in 94 the seat rails are higher on the passenger seat.
Blitz DSBC, 06 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp
Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01
Dave57 is offline   Reply With Quote
Old 11-20-2012, 01:09 AM   #44 (permalink)
CHRIS75's Avatar
The info can be found at Infinity website for " KAPPA 63.9I " i'll look for it.
But the back of the speaker is not big, i'd even say it's short and it's a little shorther than the Bose i originally had but the thing on this speaker is that the mid and tweeter things stick out so much that it 's making it hard to install.
Old 11-20-2012, 01:17 AM   #45 (permalink)
CHRIS75's Avatar
Here's a pic with the spec's:
On 316 with the old Kappa's all he had to do is make a new bracket base out of a lid of a 5 gallon paint bucket, i did this but still hits the door grill big time.
Old 11-20-2012, 01:32 AM   #46 (permalink)
CHRIS75's Avatar
Right now i am driving my car without the door panel cos i am in the middle of doing this ... darn speakers...
When i put the white bracket on the inside of the door and flip it horizontally i could almost put it flush to the door ( without getting the four plastic bases on the way ) and i saw that there is a good change that could clear the window so if you take the four white bases out and make you own to fit the white bracket it could work, but like you said ( and also that's why i didn't do that ) it may be just better make another bracket to fit the speaker and use the four white bases.
This is actually what i think to do, i want to try to make a metal bracket that i can bend a little to get the speaker inside of the door as much as i can.
Old 11-20-2012, 10:24 AM   #47 (permalink)
jordache16's Avatar
So I see on 316 he is using Kappa 63.1i 6-1/2s which based on the pictures it looks like the tweeters do not stick out nearly as far as they do on the 63.9i 6-1/2s. I tried to find a side view of the 63.1i but didn't find anything on google. Initially, I was under the impression that others have installed the 63.9i 6-1/2s in their 3S but the further along we get it seems like we may be paving our own path here.
I may consider going the component route now but based on the research I have done it is going to be a pain to install an amp to the factory HU. So who knows, maybe I will just end up leaving things the way they are now (factory tweeters, factory door speakers, Kappa 6x9s in the rear, factory HU and amp).
Old 11-27-2012, 02:58 PM   #48 (permalink)
Newbie3000gt's Avatar
Drives: 91 Mitsu 3000gt
Newbie3000gt is an unknown quantity at this point
Originally Posted by DGMAX99 View Post
Stock system, no issues with the door speakers, or dash, which I have also replaced with Infinity's. I'm pretty sure my rears could use replacement due to the shear age, but they still sound great and don't rattle. My 3000 only has a little over 21K miles and has been kept sheltered (98 SL model). I realize that has little to do with the surrounds rotting tho...
GTFO 21k Lyin azz!!!!!!!!!!!!!
Newbie3000gt is offline   Reply With Quote
Old 11-27-2012, 05:08 PM   #49 (permalink)
Lunchbox's Avatar
Drives: 1992 Stealth RT/TT
Lunchbox is an unknown quantity at this point
Feedback Score: 3 reviews
My 1992 RT/TT has 36k on it. Took a pic while I was outside this morning changing the driver window reg. They are out there. I bought mine from a collector in NYC who needed room for car #32, a 4th Ferrari.
Had a 93 base from 97 to 2000 till it blew up. Fell in love with the platform and I will own a gen 1 RT/TT! Greatest car ever!......AND I JUST BOUGHT ONE!
Vehicles:
White 1992 Stealth RT/TT (Stock)
Admiral Blue 2005 Honda VTX1300c (SOLD)
Red 1997 Ford F-150 step side (Work Truck)
White 2011 Ford Crown Vic (Company Car)
Lunchbox is offline   Reply With Quote
Old 05-09-2013, 09:10 PM   #50 (permalink)
Teezlr is an unknown quantity at this point
Is there not a place that sells the factory Infinity speaker?
Teezlr is offline   Reply With Quote
