OEM Stereo help - 3000GT/Stealth International Message Center
Old 11-12-2012, 03:03 PM   #1 (permalink)
Seventy7INa45's Avatar
Drives: Jim Varney's VR-4
Seventy7INa45 is an unknown quantity at this point
Feedback Score: 1 reviews
Default OEM Stereo help
My car had an aftermarket setup installed with an Alpine head unit and a kicker 4 channel amp. The speakers were also replaced with kickers all around. The wiring was done pretty badly so there was always a ton of feedback through the sound system. I decided to put the factory unit back in, use the original amp, but use the aftermarket speakers mounted in place. I took the rear panels off, took out his wiring, and adapted the factory wiring to plug in to the speakers. The door speakers he had tapped in to the wiring harness going to the door, so I found where he broke the connection, and soldered it back together.
The head unit will light up, you can select all of the different functions, etc but no sound will play. I'm getting very frustrated. Does anyone have any ideas?
Seventy7INa45 is offline   Reply With Quote
Old 11-14-2012, 06:59 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Drives: Various Japanese
speedy25 Level 1speedy25 Level 1
Feedback Score: 3 reviews
Default Re: OEM Stereo help
Did you forget the amp under the passenger seat?
-SP
Old 11-14-2012, 12:26 PM   #3 (permalink)
nope, the amp under the seat is connected well, all connections are snug. I didn't see that he made any cuts into that wiring harness...is there a way I can test the amp?
Old 11-15-2012, 11:34 AM   #4 (permalink)
Preserve a 3S
Dave57's Avatar
Drives: '95 RT/TT
Dave57 Level 1Dave57 Level 1
Feedback Score: 38 reviews
For starters the radio does not have outputs to the speakers. The wires are there but the radio has no output. The speakers are fed from the white plug on the amp. See if the blue wire (s) has power on it and check the black wire (s) to make sure they're still grounded and make sure the black din cable goes between the two. The din cable is the radios output to the amp.
Blitz DSBC, 06 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp
Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01
Dave57 is offline   Reply With Quote
