Old 05-07-2008, 04:41 PM   #1 (permalink)
r3lapse's Avatar
Drives: Black '92 vr4
r3lapse is an unknown quantity at this point
Default Need some simple (I hope) amp wiring help
Hi all,
I just bought a '92 vr4 from Ping (pkchino) here on the forums and need some help wiring up a new amp. I am a total nub when it comes to audio systems and couldn't find anything helpful in my searches; please forgive me if this is a really stupid problem.
Anyway, here's the story: When I bought the car it came with a new sony 4-channel amp and the stock 6 channel amp, both of which were not installed. All the necessary wires are already routed to the trunk, where I want to install the amps, I just can't figure out what some of them are and where they are supposed to go.
Here's the wiring diagram I have come up with (I'm not sure if its right and have no idea what to do with the stuff circled in yellow):
If anybody could check over my diagram and let me know what I should do with the yellow circled things, I would really appreciate it. Also, here is a blank version of the diagram if it would be easier to just indicate the wirings in paint.
Thanks!
r3lapse is offline   Reply With Quote
Old 05-08-2008, 05:50 AM   #2 (permalink)
Preserve a 3S
Dave57's Avatar
Drives: '95 RT/TT
Trader Rating: (37)
Dave57 is an unknown quantity at this point
Default Re: Need some simple (I hope) amp wiring help
The 92 did not have a stock amp. they did not have 6 channels either. The dash speakers were jumpered to the door speakers in all 3s except infinity (94-99)
What I see is an amp that was using speaker line inputs. (white plugs) The square white plug in your hand needs to re wired to the white plug on your new amp The lower plug wiring needs to be confirmed with a meter but it looks like the amp power and it's turn on wire?
Blitz DSBC, 03 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp
Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01
Dave57 is offline   Reply With Quote
Old 05-08-2008, 09:21 AM   #3 (permalink)
jba3's Avatar
Drives: mitsu's stock up ^_^
jba3 is an unknown quantity at this point
It probably won't help much, but typically an amp will have a ground, a power wire, and a remote wire. At least, the 2 installs I've done were set up that way.
Did you try sending a PM to pkchino?
Old 05-08-2008, 05:12 PM   #4 (permalink)
r3lapse's Avatar
Thanks for the help guys.
@Dave57
I just assumed it was the stock amp cuase it was pretty beat up and looked OEM. How do I can I tell where to wire the speaker line inputs on the new amp?
@jba3
Thanks for the info. pkchino was going to have the wiring done by someone else, so he can't really help me.
Does anybody know what the wires in the bottom right of my pictures are? I assume three of them are the REM, +12V, and GND, but I don't know which ones and I have no idea what the fourth wire is.
Old 05-09-2008, 01:04 PM   #5 (permalink)
Preserve a 3S
Dave57's Avatar
Drives: '95 RT/TT
Trader Rating: (37)
@Dave57
It looks like there is a diagram below the high level input plug.
You really need to verify the 4 wires with a meter. One can assume red is positive but I would verify it with a meter.....
Old 05-09-2008, 03:07 PM   #6 (permalink)
r3lapse's Avatar
I bought a multimeter a long time ago, but I have no idea how to use it. I did some google searches and measuring the +12V wire seems easy enough. How would I measure the REM and ground, though? Also, why are there four wires when there are only 3 remaining inputs on both AMPS (12V, REM, and GND).
Thanks a lot for your help Dave.
Old 05-11-2008, 08:56 AM   #7 (permalink)
Preserve a 3S
Dave57's Avatar
Drives: '95 RT/TT
Trader Rating: (37)
The meter will read negatively if the connections are reversed. The turn on wire would show a positive value when the radio is turned on or car is turned on. As for the other wire I wouldn't worry about something that's not needed.
Old 05-12-2008, 09:40 PM   #8 (permalink)
jba3's Avatar
Set it to read 12V, place the black/- against a known good ground (not the wire you think is a ground on the stereo ... frame bolt or something).
Place the red/+ against the bare end of the wires. Verify what has 12V (could be ~10V to ~14V), that's your power wire. The ground wire should have under 0.25V (hopefully 0). Your remote wire is typically a very thin wire, used only to send a signal to the amps that the head unit is powered up.
I haven't wired up a system that used more than positive, ground, and remote, including multi-amp and capacitor systems.
Turn on wire = remote wire in this case
